Here is an Android 4.2.2 Jelly Bean rooted firmware for the Vido Yuandao Mini One (M1) RK3188 tablet based on latest official update from Yuandao dated 2013/07/18
(原道Mini One-4.2.2-20130718-ZZ-正式版固件.zip)
Build information:
Kernel: Linux version 3.0.36+ (wbj@tchip-super) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #141 SMP PREEMPT Thu Jul 18 23:05:07 CST 2013
Android 4.2.2 JB: rk31sdk-eng 4.2.2 JDQ39 eng.wbj.20130718.195038 test-keys
- root with latest SuperSU version 1.41 (free version)
Download: kasty-yuandao_vido-mini_one-422-20130718-rooted4.zip
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have a Yuandao Vido Mini One tablet to test the custom firmware.
chadoe, elan71, oleg.log, sloom, smschu, pdx0r, renwklo, chriz8912 If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/06/18
Hi
Works fine on my Mini.
The only problem I have is to reconect the Wlan at home.
It needs a verylong time, almost 10min to reconnect. I see the grey Wlan symbol on the right upper corner and I have to wait until it will be blue. I tried to switch of the Wlan or the complete Tabled, but no succes.
Has anyone the same problem?
He flashed the firmware on a different tablet (probably identical to this one) and therefore some issue can appear.
2013/08/13
I'm using this image with pretty good success on my Mini One. I found a couple problems, not sure if it's the firmware or something I did, but:
The battery stats don't work (battery usage data isn't available)
When pressing the app switcher button (bottom right), and choose a previously run app, sometimes that app doesn't pop up. The app you were currently using just comes back.
Scrolling by swiping a web page, or the Play Store, doesn't work too well. It's very laggy.
The Google search bar is annoying, but easy to remove.
I would like a way to modify the boot screen to remove the chinese. Other than that, the software works way better than the stock 4.1 that came with it.
James
2013/08/16
I had good success using this firmware, but need help getting more access to the google play store, and I also have a problem with google maps.
I logged onto the play store using the stock rom, and then with two installations of this firmware. I have an app that according to google play can be installed on the stock rom, but not after installing this one.
2013/08/13
After further use, I've found the same problem with Google Maps. I also have the rebooting issue, especially right after the tablet first boots. It will freeze for 10 seconds after I click on an app, which doesn't start, then the screen goes black and it shuts down and restarts.
I haven't found any info as how to fix these issues as well as the issues I mentioned before with app switching and battery usage information not available.
If a new ROM comes out, will I have to reinstall all my apps?
James
Upgrading to a new firmware will erase your data. You can easily make a backup with Titanium Backup available for free on Google Play Store.
https://play.google.com/store/apps/details?id=com.keramidas.TitaniumBackup
bigducket If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
A custom firmware with this firmware update will be made shortly.
elan71 If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
Currently Online: portvein
83 Guest(s)
Devices in use: Desktop (68), Phone (16)
montolla
portvein
POELE
hststs44
lokeshreddymtpl
scoopsat
