Vido N80RK by Oma rocks – JB 4.2.2 Edition v3.4
- CWM 6.0.3.1 recovery
- system ext4
- latest kernel
- internal Storage 4,0 GB
- TabletUI & Multi-User
- ethernet support
- init.d support
- gameloft compatible
- USB-Hub enabled
- gamepad compatible (PS2, XBox, ...)
- kernel modules (cifs, tun, lan, serial)
- latest hosts, su, su-binary, busybox
- FX Sound
- Reboot Menue, CPU Tweaker, Pimp my Rom
- Dateimanager HD (Root)
Vido N80RK cRom v3.4
format_NAND Instructions see download pack (written for Chuwi V88).
adminPer aspera ad astra, we rock the Tablets !
What is your tab? Is the kernel still booting?
2013/11/06
Works pretty fine on my tab this rom. The only issues I have encountered are some random freezes but that only started with the recent chrome update.The other one is that the battery indicator stays at lets say 30% then after some time using heavy apps drops at 15%. But I know how much time the battery lasts so its not much of a bother. Otherwise its a great quality rom.
2013/09/25
Just downloaded and installed this rom on the weekend. All went pretty well and the rom has (so far) none of the problems that the other custom roms have (that of eventually slowing to a crawl due to rknand_buffer taking up too much CPU cycles).
However, I do note that the camera app does not work. When I start the camera it pops up a message "Unfortunately, Gallary has stopped." If I start the Gallery itself, then it seems to work ok, just no camera.
Any ideas as to how to fix that one?
76 Guest(s)
Devices in use: Desktop (71), Phone (5)
hans41
rickybk
soniya07
ironmangitar
