Here is an Android 4.2.2 Jelly Bean rooted firmware for the Yuandao M10 / Vido M10 (ZZ model) based on latest official update dated 2013/12/14.
(M10-4.2-20131214-ZZ.img / M10-4.2-20131214-ZZ-固件+刷机工具+刷机教程+驱动.rar)
Build information:
Kernel: @Linux version 3.0.36+ (root@zhangboyu-desktop) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #517 SMP PREEMPT Fri Dec 13 17:27:15 CST 2013
Android 4.2.2 JB: rk30sdk/rk30sdk/rk30sdk:4.2.2/JDQ39/root.20131213.172908:eng/opinions-on-teclast-p90hdst-keys
ro.rksdk.version=RK31_ANDROID4.2.2-SDK-v1.04.00
- root with latest SuperSU version 1.89 (free version)
- NEW! optional ClockworkMod (CWM) Recovery easy install package
Notes:
- any update received thru OTA may interfere with our custom firmware, we recommend not to apply any OTA update
Download: kasty-yuandao_vido-m10_zz-422-20131214-rooted4.zip
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have a Yuandao M10 / Vido M10 (ZZ) tablet to test the custom firmware.
2014/01/06
Can I ask you something?
I need your help.
I'd like to lower brightness level of display below its factory minimum.
I tried to edit values in framework-res.apk/res/values/arrays.xml
<integer-array name="config_autoBrightnessLcdBacklightValues">
<item>5</item>
<item>20</item>
<item>50</item>
<item>70</item>
<item>150</item>
<item>250</item>
</integer-array>
But my decompiled "framework-res.apk" does not have the directory "/res/values" at all!
Would you change this or future custom firmware? Please, add the ability to change minimum brightness to the value of "1" for example. And tell me how to do that. Do not offer apps like "Screen Filter" because I wanna save the battery.
I have read almost all XDA but nobody knows about android 4.2.2 (I mean how to lower brightness)
Thanks in advance
2014/02/06
Maybe I am missing something, but I just bricked my Vindo M10 while trying to install new image I downloaded:
I used rkbatch tool ver 1.7
used windows 7 as host computer
there were issues getting the M10 into proper mode where driver was recognised, the reset proceedure for this tablet was unclear, what seemed to work was setting M10 in to usb debug, turning off, then turning on while holding vol+ button, then driver included with RKBatcht too would install.
RK batchtool could now see M10 (green Box)
1) set firmware path to new image
2) executed restore
test device sucess
Lower Format Success
test device success
check chip start success
get flash info Success
Prepare IDB Fail
Unplugged and replugged USB, batch tool box turns green, tried restore, and it sequences through same steps and stops on Prepare IDB
any help would be appreciated
61 Guest(s)
Devices in use: Desktop (57), Phone (4)
