[ ROM ] Yuandao M10 / Vido M10 (ZZ model) Android 4.4.2 KitKat custom rooted firmware (2014/01/17)
Bigboss80
Forum Posts: 11
46
2014/07/28 - 22:00
Done... Did't work... :-(
Had a try with the Rkbatchtool included, that has config dont working.
So downloaded Rkbatchtool 1.7 + rockchip drivers 3.5 , x86 version.
When i load Rkbatchtool, 1.7, rockchip drivers 3.5, (this works) i get the blue square, not the green: tried to update, but i get "download IDB fail" and the square goes red. Same thing also if i try with restore mode.
Some advices? I really want now to kill Real Racing 3 developers.... :-(
PS: i notice that the immage M10-4.2-20140609-AZ固件+刷机工具+刷机教程+驱动固件M10-4.2-20140609-AZ.img in the
FW ver: says 4.1.01....
FW time: 2014-06-09 09:18:06
support: RK31
boot ver: 1.27
boot time: 2013-09-13 09:46:43
Its Bricked? I'm so frustrated and angry... My kids looks at me in tears... :-(
 PS: done power key + vol - , but nothing happend. There is an order to press buttons? Anyway the tablet seems to be already off.
@Chommy: sei italiano?
Chommy
Italy
47
2014/07/28 - 22:37
Si, dalla Sardegna :-)
48
2014/07/29 - 07:22
Best is you use a PC with win7. Do not use an usb3.0 port.
Here is a driver assistant: http://crewrktablets.arctablet.com/?wpfb_dl=1187
De-install driver first, then install again.
Then flash the loader in mask-rom mode: http://crewrktablets.arctablet.com/?wpfb_dl=1631
Do the steps shown in the instructions picture.
Tab is still in flash-mode, continue now with RKBatchTool (Restore).
49
2014/07/29 - 07:25
Chommy said
Hi Oma, I've alredy installed original 4.4.2 firmware, made the root and installed the cwm. Can I jump the first three steps? Thanks.
No, custom firmware comes with an other patitition layout (larger internal storage).
Chommy
Chommy
Italy
50
2014/07/29 - 22:05
Hi Oma, I've installed your rom using the istructions. Very well but the wi-fi don't start.
Do you have any idea?
Thanks.
Chommy.
Chommy
Italy
51
2014/07/30 - 18:14
Hello Oma, for test I tried to load the kernel of the model ZZ. The Wi-Fi worked again but the touchscreen detects the positions rotated by 90 degrees.
It's possible to make a Frankenstin kernel :-) ?
Thank you.
Chommy
Bigboss80
Forum Posts: 11
52
2014/08/01 - 23:06
Done, work well untill i press download in RKDevelopTool, then it get me in to: (look image)
Immagine.jpgImage Enlarger
What can i try now?
Bigboss80
Forum Posts: 11
53
2014/08/02 - 20:30
Oma, any advices?
54
2014/08/02 - 22:32
Try to flash the v2.10 loader first then the other way round.
Bigboss80
Forum Posts: 11
55
2014/08/02 - 23:06
getting even worst i think:
Immagine2.jpgImage Enlarger
Tryed also 1.24 again, now dont work anymore, same report in log.
osef78
56
2014/08/02 - 23:41
Hi there,
I'm afraid that I am in troubles with the upgrade of my brand new Vido M10...
I just received it this afternoon and wanted to root it ASAP, with the firmware we are talking about in this thread.
The issue is that I didn't pay attention to the AZ / ZZ model type distinction. And mine looks to be a Vido M10 AZ, not ZZ.
 Just to let you know, the upgrade process went pretty well, but at the end, the tablet is definitly unusable: The device is booting but the tactile mode is wrong or stucked, I can't even log in.
Apart from this, I can still connect to the device using the Rockchip Batch Tool utility, which sounds like hope to my ears... ;)
But still, I really need to good back the 4.4.2 factory firmware or so...
Would anybody now how to proceed and whre to find this firmware?
Many thanks in advance.
EDIT: OK guys, sorry to bother you with this pretty much off-topic, but if this can help noobs like me:
Here is the link to download the (obviously unrooted) kitkat firmware released by the vendor for the AZ M10 for those how would have unfortunately tried this rom on their AZ device:
On:
http://www.yuandaocn.com/download.aspx
Grab this package: http://pan.baidu.com/s/1i3HuoF7
unrar it and search for the .img file inside the folder. Obviously you can use the Rockchip Batch Tool (link at the top of the topic) to flash your device back to life ;)  ** only for AZ device, again. The rom is intended to run on ZZ and it does this good  **
57
2014/08/03 - 10:10
Ok, fine. One AZ tab back to life.
But what do you mean by that?
@ Bigboss80: try to flash the firmware from post #56 with RKBatchTool. If this fails again you need to open the tab:
osef78
58
2014/08/03 - 10:39
Impressive unbricking process :-)
@Oma: sorry, my sentence was unclear: I just added this warning since I give a link regarding the AZ model (the vendor stock firmware) on a topic dedicated to the ZZ. I just wanted to remind those who own the device mentioned in the thread title that my link is useless for them and that they should use your ROM ;-)
By the way, I didn't find a custom rom for my AZ yet (there is another topic on this forum where someone makes the same statement). I didn't manage to root it as well...
Bigboss80
Forum Posts: 11
59
2014/08/03 - 15:28
Hi Oma, tried to flash the firmware from #56, doesnt work for me.
Opened the tablet, tried to short 8-9 , 7-8, than tried Oma_DevelopTool_Refresh (admin mode) with both 1.24 and 2.1.
1.24 worked well thru erase ID block, Erase all BLocks, than truck in download.
2.10 worked well thru erase ID block, struck Erase all BLocks and download.
I still get that my tablet is in Mask Mode, blue square, but get IDB download fail!
I'm goin crazy with this!!!
take a look to Logs...
What the hell got to do???
60
2014/08/03 - 15:34
Looks like a defective NAND. What about flashing update.img with RKBatchTool after shorting pins?
42 Guest(s)
2 Guest(s)
Devices in use: Desktop (40), Phone (2)
petersons
abid
PUNTOUS
ahujcibugs
edneijovenase
thanhgom2006
