[ ROM ] Yuandao M10 / Vido M10 (ZZ model) Android 4.4.2 KitKat custom rooted firmware (2014/01/17)
s7yler
Forum Posts: 17
2014/05/03 - 13:51
I can't really remember anymore. But you can install Arctools.apk
http://www.arctablet.com/blog/archos-tablet/arctools-google-apps-and-market-installer-for-archos-gen8-youtube-fixed/
In arctools app I believe you the have option somewhere to reboot tablet into recovery mode if your rooted.
darkgentle
2014/05/03 - 14:01
@s7yler i am not rooted yet i got the tablet yesterday and i am trying to flash it with the kasty rom to 4.4.2 from this forum but any time i press switch to change the pink to green the tablet switches off. do i have to root it first and if so how do i root it? i check on the device and it says i have root access cos the tablet came without any Chinese app on it so i dont know if it was already rooted. thanks
s7yler
Forum Posts: 17
2014/05/04 - 13:34
download "Root Checker" from the Play Store, and see if your rooted or not.
(mine also didnt have any chinese apps on it, but still it was not rooted when I got it)
If your on 4.2.2 and not rooted, read the info in the video description in my video here, there are instructions to find info how to root it (remember also to subscribe to my channel if you like it):
darkgentle
2014/05/04 - 22:00
@s7yler it wasn't rooted but after a bit of reading I have manage to root it but still I can't switch it from pink to green! Does the tablet have to be in recovery mode before I can install the custom ROM? Or do I have to install the arctool to be able to install the custom ROM? I'm a bit stack now. Thanks anyway for your time
pm1111
2014/05/15 - 21:09
First thank your for your work.
Now my problem:
I've installed your 4.4.2 rootet firmware successfully. But as there was some issues with tv streaming apps I wanted back to previous version with your rooted version of 4.2.2. But the process has failed and now my Vido 10 is bricked. Volume + or volume - in combination with power button doesn't work. Any other idea to unbrick?
Thanks Received: 3177
2014/05/15 - 22:01
pm1111
pm1111
2014/05/22 - 11:16
SmileI was able to unbrick my M10Smile. Thank you for your help. Donation made.
oblaarggag
Forum Posts: 29
2014/05/30 - 10:39
Hello there.
First of all: thank you very much for your ROM - it's really stable and working flawlessly so far.
But I have a issue which is pretty relevant to me: the sleep battery drain is way too high. Even directly after flashing the rom (no config and no apps so far), the battery drains like 2-3% per hour sleep.
Could you please check this? BetterBatteryStats reports that the tablet goes to sleep - but still, the tablet won't make 2 days sleep... which is no very handy.
Thank you very much.
Best Regards
ninppuukamui
2014/06/29 - 12:55
I also thank you for the rom, and also have the same problem. I have the paid version of Greenify, and I have Greenified everything, including system apps, and the battery drain is still the same; I don´t make it pass three days with very light use (a few hours a day if even), and in flight mode with WiFi off.
Any help would be greatly appreciated, and I´m happy to provide BBS logs or any other additional information.
Cheers!
targa
Forum Posts: 14
2014/07/22 - 11:16
hi
any news on M10 ROM ?
It seems I have one, though I ordered an U30GT2, but from outside it looks like an M10.
The ROM shows up as U30GT (which it is definitely not, not even the specs are the same) on Android 4.2.2, though the details pretty much look like what I saw here for M10.
I'd like to keep it, but I have some problem:
On some occasions, I can't currently really tell when exactly, the tab is getting unresponsive. Debugging options for CPU show that  rknand_buffer process is eating all CPU capacity.
I read in other threads/forums that this can't really be fixed, just workarounded by booting from a fast SD card. Any opinions on that here ?
I'm open to patch stock or flash new ROM, but bad battery usage is not really an option (for my son, who's watching fireman sam with it ;)
Thanks, mates.
EDIT-PS: Would it help to supply logcat or dmesg in order to find our what exact HW i have ?
2014/07/22 - 18:02
A dmesg and a logcat log would be helpful.
targa
Forum Posts: 14
2014/07/23 - 22:21
Hi
here comes the logcat, though I think dmesg would be more interesting.
Anyway I have troubles obtaining dmesg. I fail to connect via adb (though Ive done this for plenty of devices before) plus, how to get dmesg if its not stored anywhere. Needs to be enabled during bootup I think!?
stupid me :embarrassed  Here you go.
2014/07/23 - 23:21
Ok, thats definitly not a Cube U30GT2, which has RK903 wifi.
<4>[ 43.796973] Current WiFi chip is AP6210(OOB)
<4>[ 44.832883] Final fw_path=/system/etc/firmware/fw_RK901a2.bin
<4>[ 44.832919] Final nv_path=/system/etc/firmware/nvram_AP6210.txt
<4>[ 44.832960] Final conf_path=/system/etc/firmware/config.txt
2014/07/23 - 23:30
You kernel string indicates that this is most likely a Vido M10 ZZ.
Linux version 3.0.36+ (root@zhangboyu-desktop) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #501 SMP PREEMPT Wed Dec 4 15:45:04 CST 2013
See here: http://www.arctablet.com/blog/forum/yuandao-vido-tablets/rom-yuandao-m10-vido-m10-zz-model-custom-root-android-4-2-2-firmware-20131214/
Chommy
Italy
2014/07/24 - 00:02
I'm new to the forum, I recently purchased the M-10 but I found to be the AZ series.The ZZ series firmware are compatible? Sorry for the bad English. Thank you.
83 Guest(s)
Devices in use: Desktop (74), Phone (9)
desluk
cimoral
merlin077
nrod
midnight-gr
Pajaro047
