Which Android? Have you checked it with TUN.ko Installer (Play Store)?
2014/08/08
Which Android? Have you checked it with TUN.ko Installer (Play Store)?- Oma -
hi Oma. tun.ko for rk3168 on jb 4.2.2... already tried tunko installer from playstore. but once we turn on vpn, device hangs and reboots.Â
devices tested:(rk3168)
Starmobile Engage 7+
Starmobile Engage 7 Lite
2014/12/29
I have this semi-bricked "Lexibook tablet junior 2", model MFC270xx (xx is language) where I managed to erase the flash with android tools before I had the factory image file handy. The supplier is not able to supply the original image, so Im kinda stuck with a glowing brick here.
The image kasty-yuandao_vido-n70s-422-20130801-rooted3Â runs on it, except:
-The native screen resolution is wrong. This tablet has a 800x480 screen.
-The touch orientation and scaling seems wrong, because Im not able to unlock it, but I can move .. something.
All buttons work as they should.
The mentioned image is set to default usb file share, so I cant access it on adb, not even after switching mode with android tools, nor in recovery mode. But android tool work.
Anyone got a clue what to do? Do you know of any image for the RK3168 and 800x480 screen res that I could try?
Here are some firmwares for 800*480:
http://pan.baidu.com/share/link?uk=87190310&shareid=2346722488
http://pan.baidu.com/share/link?uk=87190310&shareid=1098081838
http://pan.baidu.com/share/link?uk=87190310&shareid=3597976625
http://pan.baidu.com/share/link?uk=87190310&shareid=1914724368
Good luck.
Try with a download manager: http://www.rockchipfirmware.com/sites/default/files/fdminst.zip
2017/11/30
Oke.....
I was looking for a long time for a fitting rom for my Asian Tablet.Its from the same manufacturer as this one.But i got really confused reading the post on freaktab and here.....Is this, what i assume...For the RK3168 with the powervr SGX540 gpu...
I have an tablet what looks like the touchmate mid101...Many who use that housing, but mine has the 1.2ghz rk3168....I would already be very happy with this rom, rooted and clean....But i dont know if it fits, some tablets are the same i quess...But the next comment and it looks like the 1.6ghz rk3168......??And i know most things must be the same, but maybe thats changeable..Screen is also 1024x600 etc....But the wifi chip of these tablets....Also the realtek RTL8188ETV chip....If so then its the same as mine..I hope someone can clear this....
Brand name: Empire Electronix (Manufacture :Rockchip)
Device : Rockchip M1002B
Android :4.2.2
Processor : RK30board
Cpu Max Freq : 1200 Mhz
Cores : 2
System Ram : 1.00GB (Some apps say 1500mb)
GPU : Imagination Technologies PowerVR SGX 540
Audio Chipset : Rk30sdk
Internal Storage : 1008Mb(132 mb free)
Display Size : 1024x600(12.36'')
Screen Density : 90 ppi (160dpi)
Refresh Rate : 82.34 Hz
Back Camera : 1.9 MP(some apps : 2Mp)
Front Camera : 0.3 Mp
System :
Model : M1002B
Manufacture : Rockchip
Android : 4.2.2
Api Level : 17
Kernel : 3.0.36+20131118....
Compilation : V1.01.JDQ39...
Board id : YK108-RK3188-V1.0
Processor :
Processor : Rk30board
Instructions sets : armeabi-v7a, armeabi
Max Freq : 1200Mhz
78 Guest(s)
Devices in use: Desktop (73), Phone (5)
tdomnic024
otismaibe
Tsuna77
docentik2006
nechey
