[ ROM ] Vido Yuandao N101 quad-core tablet (N101RK) root Android 4.2.2 custom firmware (release 2013/07/25)
nothing111
2013/10/14 - 18:37
Thanks @admin with custom rom and @theelion with your report.
I'm waiting a new custom rom too.
I get trouble with old rom, it is lag, some games run fast but run slow after that.
Hoping custom rom can solve this problem, remove chinese app...
nothing111
2013/10/14 - 18:41
theelion1,
Sorry, I just noticed the link you posted is more recent than our custom firmware in post #1.
Later today, I'll post a new custom firmware build based on 2013/09/12 firmware.
theelion1 said
I already tried your custom ROM. (see post nr 2).
The internal memory is fine (4Gb).
Only these probs/remarks :
1/the smaller text is not sharp and some parts seems to be missing. It looks not all dots are there. For instance in <settings> if you choice one, on the right screen you can hardly read the numbers in <storage>.
2/brightness : when you use the buttom on the homescreen, the L is very,very dark. When you look to display-brightness', it stands on the lowest level.
I'm waiting a new custom rom too.I get trouble with old rom, it is lag, some games run fast but run slow after that.
nothing111
2013/10/14 - 19:17
theelion1 said
I just tried the originel ROM from http://www.yuandaocn.com/download.aspx :
N101四核RK-4.2-20130912-ZZ-固件+刷机工具+刷机教程+驱动
N101四核RK-4.2-20130912-ZZ-正式版固件.zip适用于机身后壳序列号中有ZZ字样的机器  [本地下载]   [迅雷快传下载]
It works fine but :
1/only 1Gb internal memory instead of the desired 2 o3 4 Gb.
2/lots of chinese apps that can't be removed.
Now, I don't have these probs :
1/the smaller text is not sharp and some parts seems to be mssing. It looks not all dots are there. For instance in settings if you choice one, on the right screen you can hardly read the numbers in storage.
2/brightness : when you use the buttom on the homescreen, the L is very dark. When you look to display-brightness', it stands on the lowest level.
So waiting for another customROM.
So you use restore button or upgrade button?
Thanks Received: 3170
2013/10/14 - 21:30
mobydog
2013/10/16 - 16:19
Hi, admin.
I have successfully restore both previous and present version of your 4.2.2 rom. It worked. Great job.
However,  4.2.2 version do not come with gravity gyroscope calibration. It's a bit troublesome, as it only auto rotate once and then stuck at that orientation. launching some programs or playing games will cause this. I would have to restart it to use in landscape. 10.1 screens are meant to be use in landscape.
Also, 4.2 version andriod have disabled some functions which are important to me.. sound booster and equalizers no longer works. Yet Andriod in any versions are notorious for soft ringtones and system sounds.
Just wondering, whether you have archived previous rooted and un bloated 4.1.1/2 version rom of this tablet. If so, can you direct me a link?
It would also be great to upgrade rkchip to sdk02 too.
Thanks.
theelion1
Thanks Received: 7
2013/10/16 - 19:40
Thxs a lot.
For me all works fine.
DCMANUEL
2013/11/15 - 10:15
I have problem with my yuandao N101rk Quad Core,
I install some apps from android market and as I saw it was slow, turn it off and went back to turn on and now stays on the screen that is loading the system as shown in the 1st photo, i follow the steps I saw in the forum for recovery and I get a screen with the android sleeping a red triangle.
I need help to get my tablet or already dead? thanks.Tablet-1.JPGImage EnlargerTablet-2.JPGImage Enlarger
2013/11/15 - 10:21
Looks like your tablet system is somehow corrupted and your device is booting in recovery mode.
If you don't have any data to save on the tablet, you can reinstall a firmware such as the one from post #1,
you'll need to flash using Rockchip Batch Tool version 1.7
Currently Online: avv2011
78 Guest(s)
Devices in use: Desktop (64), Phone (14), Tablet (1)
avv2011
leadpan101
jumbo65
kalkpits
m12k
StatusQ
