Here is an Android 4.1.1 Jelly Bean rooted firmware for the Yuandao Vido N101 (N101RK) quad-core RK3188 tablet based on latest official update from Yuandao dated 2013/07/25
(N101四核RK-4.2.2-20130725-ZZ-正式版固件.zip)
Build information:
Kernel: Linux version 3.0.36+ (swfour@SW-desktop) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #30 SMP PREEMPT Mon Jul 29 21:05:37 CST 2013
Android 4.2.2 JB: rk30sdk/rk30sdk/rk30sdk:4.2.2/JDQ39/eng.swfour.20130729.195342:eng/opinions-on-teclast-p90hdst-keys
- root with latest SuperSU version 1.60 (free version)
- NEW! kernel modules (cifs, tun, lan, serial, xpad) compiled by Oma & Crew RKTablets, thank guys!
Download: kasty-yuandao_vido-n101rk-422-20130725-rooted4.zip
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have a Vido Yuandao N101RK tablet to test the custom firmware.
nothing111 If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/10/01
I tried this firmware.
Two remarks :
1/the smaller text is not sharp and some parts seems to be mssing. It looks not all dots are there. For instance in settings if you choice one, on the right screen you can hardly read the numbers in storage.
2/brightness : when you use the buttom on the homescreen, the L is very dark. When you look to display-brightness', it stands on the lowest level.
The following users say thank you to theelion1 for this useful post:
nothing111
2013/10/11
Someone help me plz.
I have some matters need your help. I do not know chinese and I read some english guides but i do not understand to flash my tablet Vido N101RK (Rockchip 3188). Can you guide me step by step i.e:
Fisrt: enable or disable 'debug usb'
Second: open Rockchip flash tool.
Thirds: plug usb cable to tablet and PC
Cause i read some guides when i plug usb with debug enable but my PC can not install driver (wrong driver) and Flash Tool has pink color at slot 1.
2013/10/01
hello,
I followed this guide : https://www.topnotchtablets.com/RK3066firmware and http://rockchipfirmware.com/sites/tntfiles/RK3066updateProcess.pdf
It's for a RK3066, but it's all the same for a RK3188.
To get in the flashmode :
With RKBatchtool open, press these buttons and hold them in this order:
Volume Down
ESC
Power
Hold until the PC sees the tablet in flash mode.You will see a green buttom.
Only you need a different version of the Rockchip batch : version 1.6 or 1.7.
nothing111
2013/10/11
theelion1 said
hello,
Volume Down
ESC
PowerHold until the PC sees the tablet in flash mode.You will see a green buttom.
Thanks @theelion.
Cause when i install driver with your guide it appears on devices manager with name 'class for rockusb devices' and when i connect tablet with PC, the tool reports 'connected' with pink color not green.
I use version 1.7. something wrong?
2013/10/11
theelion1 said
I never saw the pink color.Are you sure you used the right drivers for you PC?
Be sure the tablet is in Flash mode!
If you see the pink buttom, try the swith-buttom on the RBBatchtool.
Thanks so much, it changes green color. And about the RKTool so we choose upgrade or restore for original rom from vido (i dowloaded it from main website with chinese language but i do not know chinese 'cause in the picture vido guide chooses the second button if in english version = upgrade and the third button = restore)
I hope you can help me.
So do you have some rooted roms for this tablet?
if have can you give me or send me the links.
2013/10/01
First I used the one on top of this page : http://www.arctablet.com/blog/downloads/firmware/Yuandao_Vido/kasty-yuandao_vido-n101rk-422-20130725-rooted4.zip
But I have with this one some probs (see higher)
I use Restore.
From with site did you get the originel ROM? From Vido?
nothing111
2013/10/11
I use Restore.
Yes, i dowload from vido, here the link http://www.yuandaocn.com/download.aspx
You can check it, so how about the rom you using, it is better than the old or not ( the old is 4.1.1)
2013/10/01
I just tried the originel ROM from http://www.yuandaocn.com/download.aspx :
N101四核RK-4.2-20130912-ZZ-正式版固件.zip适用于机身后壳序列号中有ZZ字样的机器 [本地下载] [迅雷快传下载]
It works fine but :
1/only 1Gb internal memory instead of the desired 2 o3 4 Gb.
2/lots of chinese apps that can't be removed.
So waiting for another customROM.
nothing111You can try our custom firmware from post #1 if you want the Chinese apps removed. For the increased apps storage space, I'll review our firmware as there may be a mistake in the partition size settings.
For the rest of your problems, it's quite likely related to issues from the manufacturer software and not easy to debug without having the exact tablet model to check the problems on...
theelion1,
Sorry, I just noticed the link you posted is more recent than our custom firmware in post #1.
Later today, I'll post a new custom firmware build based on 2013/09/12 firmware.
2013/10/01
I already tried your custom ROM. (see post nr 2).
The internal memory is fine (4Gb).
1/the smaller text is not sharp and some parts seems to be missing. It looks not all dots are there. For instance in <settings> if you choice one, on the right screen you can hardly read the numbers in <storage>.
2/brightness : when you use the buttom on the homescreen, the L is very,very dark. When you look to display-brightness', it stands on the lowest level.
nothing111Most Users Ever Online: 749
Currently Online: vlk88
112 Guest(s)
2 Guest(s)
Devices in use: Desktop (102), Phone (9), Tablet (2)
vlk88
JozekPL
Nobrubbr
pall668
Debilai1234
senaslapinas
