Here is an Android 4.2.2 Jelly Bean rooted firmware for the Vido Yuandao Mini One (M1) RK3188 tablet based on latest official update from Yuandao dated 2013/10/19. This firmware is designed for Mini One models having "ZZ" in their tablet case serial number.
(Mini one-4.2-20131019-ZZ-固件+刷机工具+刷机教程+驱动.rar Mini one-4.2-20131019-ZZ.img)
Build information:
Kernel: Linux version 3.0.36+ (wengbj@tchipserver1) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #149 SMP PREEMPT Sat Oct 19 15:24:31 CST 2013
Android 4.2.2 JB: rk30sdk/rk30sdk/rk30sdk:4.2.2/JDQ39/eng.wengbj.20131019.135214:eng/opinions-on-teclast-p90hdst-keys
ro.rksdk.version=RK31_ANDROID4.2.2-SDK-v1.04.00
- root with latest SuperSU version 1.69 (free version)
- NEW! optional ClockworkMod (CWM) Recovery easy install package
Download: kasty-yuandao_vido-mini_one_zz-422-20131019-rooted4.zip
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have a Yuandao Vido Mini One tablet to test the custom firmware.
chadoe, twankeizer, Tomcar, Lexis2001, suisse4all, gurriata If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/09/15
First of all I´d like to thank you for your hard work in customizing the firmware and removing some unnecessary apps from it.
I´ve just upgraded my Mini One (ZZ model) from 20130718 to 20131019 firmware and one change I´ve noticed is that it is no longer possible to adjust the screen brightness from the quick settings dropdown menu. Instead of this there is a signal strength indicator for cellular network which this tablet isn´t equipped with. I don´t know if this is also in the "official" firmware. Is there any chance to revert it back to the former set of quick settings buttons?
The changes you are mentioning should come from the manufacturer's firmware, and are not related to our custom firmware.
As for the cellular network strength, it's probably related to external 3G dongle support that has been integrated in the new firmware.
Lexis2001 If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2014/01/06
Hello 2 all!
I flashed my Vido mini S with Rockchip Batch Tool version 1.7, with "Upgrade" button.
It works fine! Thanks a lot. Can I ask you something?
I'd like to lower brightness level of display below its factory minimum.
I tried to edit values in framework-res.apk/res/values/arrays.xml
<integer-array name="config_autoBrightnessLcdBacklightValues">
<item>5</item>
<item>20</item>
<item>50</item>
<item>70</item>
<item>150</item>
<item>250</item>
</integer-array>
But my decompiled "framework-res.apk" does not have the directory "/res/values" at all!
Would you change this or future custom firmware? Please add the ability to change minimum brightness to the value of "1" for example. Do not offer apps like "Screen Filter" because I wanna save the battery.
Thanks in advance
2014/02/13
Hi
I got a Vido Yuandao Mini One tablet (M1, ZZ model) root Android 4.1.1
When I try to update with
In Rockship Batch tool 1.7 I see msg
******* Upgrade Action *******
"This operation didn't do, because of not supporting"
Connected Devices 1 {8-3}
FWVer = 4.1.01
BOOT ver = 1.24
Support = RK31
It is very good that you prevent upgrading, if it is not supported (so that the device is not ruined).
But could you please shed some light to why it might not be supported?
I'm a newbie in this area of flashing android so I might do something very silly mistake?
This is the information I see in "android settings"
Model number= Minione
Android version= 4.1.1
Kernel versiojn 3.0.36+ zhansb@tchip-super #857 SMP PREEMP Wed May 22 17:57:00 CST 2013
Build number = RK30_ANDROID4.1.1SDK-v1.00.03
rk30sdk-eng 4.1.1 JRO03H 20130522.121050 release-keys
Status gives this serial number 46GR22RZV1
On the hardcase (on the back of the VIDO) the ZZ is included in the serial number.
Thank you,
qa4ever
Yes: http://crewrktablets.arctablet.com/?p=3910
2013/07/23
Yes: http://crewrktablets.arctablet.com/?p=3910- Oma -
I just installed this ROM.
It works, however, the rotation and the camera is screwed up
102 Guest(s)
Devices in use: Desktop (83), Phone (17), Tablet (2)
PATRYK-VP
victorialp23
alertscam
aolmail7448
Arc123456789
forty42
