[ ROM ] Vido Yuandao Mini One tablet (M1, ZZ model) root Android 4.2.2 custom firmware (release 2013/08/28)
2013/10/10 - 11:37
Here is an Android 4.2.2 Jelly Bean rooted firmware for the Vido Yuandao Mini One (M1) RK3188 tablet based on latest official update from Yuandao dated 2013/08/28. This firmware is designed for Mini One models having "ZZ" in their tablet case serial number.
(Mini one-4.2-20130828-ZZ-固件跟刷机工具.rar)
Build information:
Kernel: Linux version 3.0.36+ (wbj@tchip-super) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #418 SMP PREEMPT Thu Aug 29 09:17:34 CST 2013
Android 4.2.2 JB: rk31sdk-eng 4.2.2 JDQ39 eng.wbj.20130828.201302 test-keys
  • root with latest SuperSU version 1.65 (free version)
Download: kasty-yuandao_vido-mini_one_zz-422-20130828-rooted4.zip
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have a Yuandao Vido Mini One tablet to test the custom firmware.
chadoe, marcorpz, renwklo, K8, chriz8912
u8950d
2013/10/21 - 10:13
Thank you so much. This ROM is stable. However, I cannot see the change of data partition to 4GB after flashing? Other operation has no problem.
2013/10/21 - 10:17
Have you flashed using Restore button ?
Which numbers do you see at the bottom of the left side for Internal Storage (used and free) in Settings / Apps ?
u8950d
bernard.silaen
2013/10/21 - 12:27
do you have another link, like mediafare
tq
2013/10/21 - 12:29
Nope, we already provide 1 main host and 2 mirrors, there should be one with decent download speed to you.
u8950d
2013/10/22 - 02:46
Yes, i have used restore button. Flashed twice, but still have 2G data partition. Anyway, I really appreciate your effort.
(I have also a PIPO M6 and flashed your rom before. I can successfully get 4G data partition without another trial.)
2013/10/23 - 09:39
Can you please write which numbers you see at the bottom of the left side for Internal Storage (used and free) in Settings / Apps ?
bernard.silaen
2013/10/23 - 09:54
hmmm it's still not easy to download it, i have try all of the link
btw how about the multiwidows, is't working with well for all applications ?? or just a few application ??
turbienchen
2013/10/25 - 22:47
This ROM is very stable and very usable. However, the Bluetooth stack still seems to be broken (this being an Android issue after all). No way to tether my tablet with my iPhone. Connection is established but no data transferred. Waiting on an Android 4.3 release.
zoizo
2013/11/19 - 08:47
there's a new official firmware for ZZ models on Yuando site : Mini one-4.2-20131019-ZZ
I like your roms, I use them only.
Thanks for the work you do.
2013/11/19 - 10:01
60 Guest(s)
Devices in use: Desktop (51), Phone (9)
hans41
rickybk
soniya07
ironmangitar
