What do you mean with "firmware update failed"?
2014/04/25
Hi, OMA.
When I flashed the latest firmware, it started ok but half way it showed updated failed. (I didn't print screen it..)
I couldn't open the device & I press the power button for a while, it popup & it restored to factory reset mode.
Now I tried again but the batch tool cant recognize my device in both debug mode & storage mode.
I'm using Windows 8 Pro.
Yuandao Vido M11 Owner.. Need help for this tablet!!!
Sometimes the USB driver are not easy to handle, especially under win8. Pls make sure you use an USB2.0 port. Here is a tool: http://crewrktablets.arctablet.com/?wpfb_dl=1187. De-install driver first, then install.
If this fails, life would be easier if you find a win7 PC.
57 Guest(s)
Devices in use: Desktop (55), Phone (2)
