2013/11/18
First i have to thank you for your job but...
BZ & ZZ ???? what's the difference?
and why the USB drivers for my tablet can't be installed on windows 7 64bit? (my tablet isn't detected in rockchip flashing tool)
I think a video could be welcome. (or something like a pdf)
If i look in my settings: i got the "mini one BZ" build 2013/09/30 mk31.eng?????
Is there a better version without chinese apps and with a better wifi management?
VIDO Mini One 2Go RAM 16Go
Sorry my poor english. A french guy
BZ and ZZ are supposed to be two different model numbers, I don't know if there is any hardware change between the two.
According to Vido/Yuandao, the serial number on the tablet case is supposed to include the product version BZ or ZZ. If the existing firmware on your tablet says BZ, you should probably install the BZ version, have a look in our forum here for a newer version than you 2013/09/30: http://www.arctablet.com/blog/forum/yuandao-vido-tablets/
You can check below for your Rockchip driver installation problems:
127 Guest(s)
Devices in use: Desktop (123), Phone (4)
