You need to root the build first.
2014/01/26
Thanks for answering the tablet rooteada I tested this with the root checker and says is right and has installed their super-the problem is that if ArcTools use all steps go well but when I restart the recovery remains original.Los other tutorials are somewhat confusing because they really donot steps in order not to Nose as drivers android necesito.Si anyone can become a tutorial with all the steps would be very helpful
Is the firmware you are using available?
Just asking, to see what you need and if you have a fallback when you crash the tab ...
You can flash the CWM. Pack is here: http://crewrktablets.arctablet.com/?wpfb_dl=410
Just exchange the parameter in folder rockdev with the one attached (unzip first).
Maybe your tab has an other key-combination to start inot flash-modus.
If you not already have the flash driver installed, you can use this tool: http://crewrktablets.arctablet.com/?wpfb_dl=1187
2014/01/26
Thanks we will see open the android rk and the menu is marked parameter, misc and recovery, let labeled these three options? Changing the parameter file which came in descarga.El problem esque android rk rk always says not found android rock usb, how to enter flash mode on this tablet? It has no volume button
One option usb debugging thing has to be off or on
Yes, all three. Try vol+ or vol- and reset.
2014/01/26
Good tablet buy it in a Chinese website and is yuandao fhd n90 rk3066 and think it is but I'm not sure and put that came with 4.1 but when I get the tablet came with 4.2.2 I guess the problem I updated ellos.El Nose is that this tablet as it enters flash mode since rk android not me never detected the pc if I detected more storge but not rkandroid
Currently Online: chloeting2701
73 Guest(s)
Devices in use: Desktop (55), Phone (18), Tablet (1)
kevbez
xxxdddd
xxxddd
Kaydc__
jessicapeterson
Riki111
