[ ROM ] Visture V97 HD (and compatible N90FHDRK - U9GT5 - X900 PAD 9719 QR) rooted Android 4.2.2 firmware (release 2013/10/10)
speko
46
2013/12/13 - 13:25
The following users say thank you to speko for this useful post:
yaneche
Thanks Received: 3171
47
2013/12/13 - 19:11
hdeg2007, speko, Narag, salinok
hdeg2007
48
2013/12/13 - 20:47
I have a Dragon Touch DT R97 Quad Core RK3188 and have been looking for a custom rom, with no luck. I then started to look for other devices that looked like mine with much the same hardware. Found your rom, which I installed rom 20131010, have downloaded the new one just posted 20131120. What is the difference if any, if I may ask? I appreciate all the hard work put in to this rom. It is working perfectly on my dragon touch, have no problems with anything, Wi-Fi works great, video is smooth, and for me it is working great!
ericklr
49
2013/12/16 - 17:49
@admin :
thanks for your work. I've installed the previous version on ny brand new cube and it's working great.
speko
50
2013/12/16 - 20:58
can i ask for one more thing :) Just to replace in image with this recovery, becouse stoked didnt worked.
Thanks.
https://drive.google.com/file/d/0B5z3hAWDb1ATanpOQl8wVFc5XzQ/edit?usp=sharing
sgparkin
Forum Posts: 11
51
2013/12/18 - 22:51
Tried this ROM - on generic RK3188 retina device (don't know manufacturer). As per my posts re the newer version, the battery is reported as 0% and charging isn't detected.
Any idea how I can find a compatible ROM - just trial and error??
salinok
Forum Posts: 14
52
2013/12/22 - 12:10
Guten Morgen from Germany ;-)
I have a Xoro 9719qr and installed the lasted ROM ... simply great - thanks to the people who worked on this.
I used to run the "original Xoro JB ROM in final beta version" before installing this one. I have to admit, that on my device the new ROM runs much more smooth than the old one. I also love the 4GB data partition!
Great stuff - nevertheless some comments / questions:
1. I use OpenVPN ... and looks like there is no tun.o module baked into the ROM. The App tun.ko installer helped - now I can connect to my OpenVPN Server. Perhaps the modeule can be included in a later version?
2. I would love to use BT Tethering ... in principle it works, but: Only stock browser works when tethering the tablet with my phone. Most of the other apps are telling me "No network connection". I had the same issue on the original Xoro FW. Is someone working on this?
eliyar
53
2013/12/31 - 01:19
Hi
thank you for this great job . And Is there any possible to use cm11 or other 4.4 on N90 FHDRK?
Dvalin21
Midwest City, OK
Forum Posts: 41
Thanks Received: 10
54
2014/01/10 - 01:12
Questions:  1 is this new custom rom made from the latest update? 2 If it already is, could I get someone to do a full review with the latest firmware?  Things I need to know, Wifi range, battery life, and software compatibility.  3. I'm in the market for a tablet, and not sure if I want to get this one, or the Pipo M8HD.  Any help will be appreciated.  Thanks in advance.
Bruno Fernandes
55
2014/02/12 - 19:38
Any idea when and if there will come a KitKat ROM for Visture V97 HD?
Anyway, what's the best ROM for it. I find it kinda slow, and with lag.
Best Regards,
Bruno Fernandes
hadeskaiser
56
2014/02/18 - 12:08
hi ican not install this rom use cwm
shapipoy
57
2014/04/20 - 17:26
can anyone help me here. just trying to do a flash here but i accidentaly clicked the upgrade button, then after that it says failed. then i realized it should be restore. then i tried restore. then boom its also failed. until i unplug my u9gtv i cant open it anymore dead screen. but if i connect it in my computer RKbatchtool 1.7 it can still connect. and it is still green color in the port. :(
help me please.
Thanks Received: 264
58
2014/04/24 - 02:13
try to flash it manually in linux
shapipoy
shapipoy
59
2014/05/06 - 10:23
thanks again sir globula_neagra for the reply (Y) i already find the problem, wrong firmware trying to put the RK31 instead of RK30 . i thought i can use it in my u9gtv aha, trying to find a good ROM >.< no update for the u9gtv's. i want to change my tab performance and appearance . thanks again . sorry for late reply
209 Guest(s)
Devices in use: Desktop (194), Phone (15)
pinsky
louinsky
Arhreanymator
Bestmengqin
jr120065
Mark Naficy
