Firmware 4.2.2 of 10/10/2013
deltaman83
2013/10/31 - 19:00
Hi all,
I found a link with firmwares to download (works also with N90fhdrk, u9gt5, x900, pad9719qr, etc...). The last online was uploaded on 10/29/2013, and is dated 10/10/2013.
So this is a visture one, not online yet on visture's website.
Been installed since last night with HD display and so far, battery drain is excellent, way better than with the dragon touch firmware. Everything seems fine, quick, and stable. I just scored an average of 5800 on quadrant and 18290 on antutu's, so it's quite the same. Epic Citadel gives me a 31.7 fps
RKBatchTool is necessary to install firmware image.
I first did restore and let the tablet reboot till the end. Then I did once again but using upgrade.
Here's the link for who wants to try : http://pan.baidu.com/share/home?uk=571188649#category/type=0
Language is Russian on boot, and some apps are added than latest official like
I used ZhuoDaShi-2.2.0 to root the tablet , downloaded and installed uni-init v1.0.apk to enable init.d and then installed operation killjoy 100213 RC7 through recovery.
Just to inform you of my findings.
2013/10/31 - 23:10
julioforo
2013/11/15 - 08:33
deltaman83 said
Hi all,
Thanks.
I've posted a custom rooted firmware based on this 2013/10/10 release:
http://www.arctablet.com/blog/forum/visture-tablets/rom-visture-v97-hd-and-compatible-n90fhdrk-u9gt5-x900-pad-9719-qr-rooted-android-4-2-2-firmware-release-20131010/#p32085
Hi!
Apart from the battery drain... can you compare this rom with dragon rom?
wifi, speed...
thanks!
68 Guest(s)
Devices in use: Desktop (64), Phone (4)
