Well, that's what caused the problem. You can update this firmware by just copying the file on a microSDCard, you need to use Rockchip Batch Tool as mentioned in post #1.
You'll need to make a contact on two pins of your MiniPC motherboard and flash again a firmware on your device with Rockchip Batch Tool. Check that video for the details on how to unbrick your MiniPC.
Glad you made it, congratulations Â
I'll modify the firmware post to make it more clear about the flashing method.
WiFI on MiniPC is not very good, because the antenna is small and not very efficient.Â
There are some hardware antenna modifications on the MiniPC that may improve the situation a little, but the best thing is probably to use an Ethernet wired connection or install another WiFI dongle. I need do so some research on the subject, I'll post an article with all the details later.
I have posted an update based on a more recent firmware (kernel and Android system) from the manufacturer:
74 Guest(s)
Devices in use: Desktop (60), Phone (13), Tablet (1)
montolla
portvein
POELE
hststs44
lokeshreddymtpl
scoopsat
