[ ROM ] UG802 Android 4.1 Jelly Bean custom rooted firmware (based on MK808 and MK802 III firmwares)
Thanks Received: 3170
2012/11/05 - 15:10
I have built an Android 4.1 Jelly Bean custom firmware for the UG802 Mini PC.
This firmware is based on the MK808 system with MK802 III boot and kernel.
Download: kasty-ug802-41-011.zip
Kernel: Linux version 3.0.8+ (ant@test-desktop) (gcc version 4.4.3 (GCC) ) #33 SMP PREEMPT Wed Oct 31 14:01:34 CST 2012
Android 4.1 build: rk30sdk-eng 4.1.1 JRO03H eng.lfwang.20121026.092031 test-keys
The update.img is made to be flashed using Rockchip Batch Tool, don't install it by directly copying the update.img file on your MiniPC, it would brick it !
I am still working on improving this firmware, but it works already quite well. Users feedback is welcome, as usual.
Thanks to deadhp1, 2dark4u and finless for their tips that helped making this firmware Wink
Mewantfirmware, karburo
2012/11/05 - 17:46
I'm half done having a working firmware update thru the sdcard.
Flashing update.img from the sdcard now works, but the system files do not fit in the default system partition layout.
I'll upload the proper update if I get this feature fully working, in the meantime, flashing using Rockchip Batch Tool is necessary.
djprotex
2012/11/13 - 12:46
I am waiting for your latest update. I have bought the UG802 recently but I want to have Android 4.1.1 instead of 4.0.4. If I can get this to work, you'll receive some donations for sure :D Keep up the good work.
Mewantfirmware
Forum Posts: 14
2012/12/26 - 10:25
Booted to the "Bootloader" from Finless, then just flashed it with the "restore" button from the Flashtool
all went ok so far:
Loading firmware...
Loading firmware Finished.
Loading firmware...
**********Restore Action**********
**********Restore Start Total<1>**********
<Layer 2-1-3> Test Device Start
<Layer 2-1-3> Test Device Success
<Layer 2-1-3> Lowerformat Device Start
<Layer 2-1-3> Lowerformat Device Success
<Layer 2-1-3> Check Chip Start
<Layer 2-1-3> Check Chip Success
<Layer 2-1-3> Get FlashInfo Start
<Layer 2-1-3> Get FlashInfo Success
<Layer 2-1-3> Prepare IDB Start
<Layer 2-1-3> Prepare IDB Success
<Layer 2-1-3> Download IDB Start
<Layer 2-1-3> Download IDB Success
<Layer 2-1-3> Reset Device Start
<Layer 2-1-3> Reset Device Success
<Layer 2-1-3> Wait For Loader Start
<Layer 2-1-3> Wait For Loader Success
<Layer 2-1-3> Download Firmware Start
<Layer 2-1-3> Download Firmware Success
**********Restore Done Success<1> Fail<0> Time<160603>ms**********
system did an auto reboot so far so good, its up and running!
Can you add the "reboot" tool from the finless rom?
Is it posible to use an USB Wifi adapter to boost the wifi reception?
can you work on wifi reception?
On mine it looks like wifi is dead, just no reception whatsoever
2012/12/26 - 10:32
Poor Wifi reception is common on those MiniPCs, even some simple hardware modifications like changing the antenna won't do much. Probably the best thing is to add an external WIFI dongle, we are working on a tutorial on that subject.
In your case, it may be a kernel/system issue when using a kernel from a different model that is not supported on your device, some specific drivers (like WIFI) won't work.
Flashing back a working firmware should get you fixed.
maxxxy
Forum Posts: 21
2013/02/11 - 11:27
hello
you can put the file?
I have error on all mirrors
thanks
2013/02/11 - 11:33
The file has been removed because this firmware is a bit old and has been replaced by a newer version.
The link has been updated in post #1, download should work fine now.
maxxxy
maxxxy
Forum Posts: 21
2013/02/11 - 11:39
thanks
sorry but there is a new version??
and where can I get it?
thanks
2013/02/11 - 11:41
The link in post #1 is the update.
There is a new one in the work, we'll post it in the forum when it's ready.
maxxxy
Forum Posts: 21
2013/02/11 - 12:16
ok thanks
when will?
I ug802 the first version.
okay?
maxxxy
Forum Posts: 21
2013/02/11 - 15:40
help!!!
I tried to put this rom.
started well, only that at some point the output is written, not else space.
I rebooted and now it is fixed on the logo rikomagic
What do I do?????
help!!!
2013/02/11 - 15:42
How did you flash your firmware in the first place ?
maxxxy
Forum Posts: 21
2013/02/11 - 15:44
yes
kasty firm
2013/02/11 - 15:46
OK, but how did you install the firmware on your dongle ? which program have you used or which procedure have you followed ?
maxxxy
Forum Posts: 21
2013/02/11 - 15:48
I put the file on microsd
I started when I recognized the update and I did go.
69 Guest(s)
Devices in use: Desktop (64), Phone (5)
mogabi
ryb84
smoky551
KarlAnkho
jasondweller
2256667898
