is my UG802 dead ?
mite_jan
2013/01/27 - 23:25
HI
at first when i have started the UG802 i have noticed a blue led which probably mean that the stick is powered on
tried reseting the power couple of times and now i am not even seeing the blue led and i am seeing no signal input on the monitor ... any ideas what i can try ?
when i connect the stick to the PC (without connecting the 2 pins inside it) i get a message " usb device not recognised , one of the usb devices attached to this computer has malfunctioned, and windows cannot recognise it "
does this means it is faulty ?
here is the picture of the 2 pins (4 pins in my device ?!?!)
http://i880.photobucket.com/albums/ac9/mite_jan/P1170273_zps98e23744.jpg
is there a way i can revive it
2013/01/27 - 23:28
Which part of the motherboard do you call the 2 pins ?
Did you try the procedure on the video below ?
mite_jan
2013/01/27 - 23:48
i saw you video but on mine it is different
and i am getting a message  " usb device not recognised , one of the usb devices attached to this computer has malfunctioned, and windows cannot recognise it " without touching them
is this normal ?
even if i connect them i am getting the same thing
zoomed picture
there are also 2 more on top of them
http://i880.photobucket.com/albums/ac9/mite_jan/zoomed_zps585abfcc.jpg
2013/01/27 - 23:56
That doesn't look like normal.
I am not sure that error is related to a Rockchip Batch tool driver problem, but it may be worth giving it a try.
See in the troubleshooting section here:
mite_jan
2013/01/28 - 00:02
no that is not Rockchip Batch tool error
before i start the program if i connect the device with the computer it should say something like windows has detected ... and then ask me for the drivers to install
btw does your device detects something if you connect it to the pc without connecting the 2 pins ?
2013/01/28 - 00:04
I currently don't have my UG802 with me, I'll check when I have it around in a few days.
Hopefully a UG802 owner can help you before then.
73 Guest(s)
Devices in use: Desktop (66), Phone (7)
relaytester
revoltown
tdomnic024
otismaibe
Tsuna77
