Custom firmware fixing the audio/video sync problem on UG802 just released
Thanks Received: 3177
2012/10/30 - 18:18
According to eCCoMaNia forum member on armtvtech.com the audio/video sync issues on the UG802 should be fixed soon:
"2dark4u says he fixed audio video sync issue for good. in online streaming and in mx player also.
he wrote that he is going to make a rom based on finless 1.4a so today or tomorrow he will release his rom, here is the original post and google translation of his post..."
Господа, хорошие новости !
Мне удалось полностью побороть синхронизацию видео и звука, для этого пришлось в прошивке боба заменить всего то 200 файлов
Тестировал на Youtube HD и online видео сервисах.
Даже аппаратное декодирование онлайн потока в MX Player заработало, завтра сделаю прошивку на базе finless 1.4a.
Gentlemen, good news!
I was able to completely overcome the synchronization of video and sound, it had to be replaced in the firmware 200 files
Tested it on Youtube HD and online video service.
Even hardware decoding online stream MX Player to work, tomorrow I will do the firmware based finless 1.4a.
We will post updates when we have news about this firmware release.
2012/10/30 - 22:45
Post from eCCoMaNia on armtvtech.com, it looks like the fixed firmware is available now Wink
Here is a test version of the firmware for the UG802:
flash like finless
1. At the first start to flicker, change the resolution settings or move the slider scale, flicker disappears and will not appear again.
2. When switching resolution UG_Fixer, resets the scale, is treated as the initial boot shaky slider scale (fixed soon).
3. UG_Fixer immediately present in the firmware.
4. All tweaks of UG_fixer already applied initially, the program needs to 1360h768 and change DPI, all the checkboxes can be removed. (Functional expand)
5. replaced all the drivers and modules (everything that lay outside the core, the core remains the native).
6. Fixed problem with synchronization VIDEO / AUDIO (hard test).
7. replacing all of the codecs.
8. Many modifications of different hardware configuration (hard test what works.)
9. Test the USB webcam work, my work better, but at 2x the image sideways.
Test firmware UG802 from 2Dark
In fact released a different firmware, but:
Firmware based on Finless 1.4a by Bob and mention it I can not just leave him bottles logo by replacing the bottle animation, where it is clear that the firmware is based on his work.
the link for download:
http://www.ex.ua/view_storage/414325789771
and the original post in russian;
Вот тестовая версия прошивки для UG802:
прошивать так же как finless
1. При первом запуске, возможно мерцание, поменяйте разрешение в настройках или пошевелите ползунок scale, мерцание пропадет и больше не появится.
2. При переключении разрешения в UG_Fixer, сбрасывается настройка scale, лечится как при первой загрузке шатанием ползунка scale (исправлю в ближайшее время).
3. UG_Fixer сразу присутствует в прошивке.
4. Все твики из UG_fixer уже применены изначально, программа нужна для 1360х768 и изменения DPI, все галочки можно по убирать.(функционал расширю)
5. заменены все драйвера и модули (абсолютно все что лежали снаружи ядра, ядро осталось родное).
6. Исправлена проблема с синхронизацией ВИДЕО/АУДИО (усиленно тестируем).
7. замены все кодеки.
8. Множество модификаций настроек разного железа (усиленно тестируем что и как работает).
9. Тестируем работу USB Вебкамер, мои работают лучше, но на 2х изображение боком.
Тестовая прошивка для UG802 от 2Dark
По сути вышла совсем другая прошивка, но:
Прошивка основана на Finless 1.4a by Bob и упомянуть об этом я не могу, так же оставил его бут лого, заменил только бут анимацию, где ясно что прошивка создана на основе его работы.
Mirror for faster downloads:
2darkFW_on_Finless14a_update_img.zip
2darkFW_on_Finless14a.zip
Currently Online: 5256makc
133 Guest(s)
Devices in use: Desktop (129), Phone (5)
5256makc
e-victor
vienzo
superdavex
giorgioo@freemail.hu
suchitratiwari
