ย Please donate to support OMA and CrewRKTablets firmware work, thank you !
Samsung microSD 32GB (Class 10) Quick Review
exelletor
Blog Team
Forum Posts: 450
Thanks Received: 30
2012/04/04 - 17:09
You can format it if you want, but it comes formatted as FAT32 and if you are ok with it, you can use it straight away. ๐Ÿ™‚ I have no idea which other formats(FAT32 for sure) the Arnova 7b G2 can read/write to, I hope admin can help us here. Still, FAT32 should be the best option if you are not going to put files bigger than 4GB on it. ๐Ÿ™‚
There is no difference between using a microSD reader in your Arnova and using a separate microSD reader.
Regarding the video/music folders โ€“ I have no idea, I hope admin can help us here too. ๐Ÿ™‚ I would assume that the multimedia library automatically would recognise the files from the sd card and would put them in the video and music apps. I know that the non-stock ones(MX Video Player and PowerAmp) have their own libraries, but I really have no idea about the stock Arnova ones. You can try. ๐Ÿ™‚
Thanks Received: 3169
2012/04/04 - 17:35
Considering the card comes preformated as FAT32, you can use it immediately. You files will be readable both on the tablet or on a computer (using a microSD card reader). If you like to format the card again on the Arnova, just go to Settings / Storage settings, in the SD card panel, choose Erase SD card. it should format it and erase it.
Also, don't forget to unmount the card when you want to remove it from the tablet (see Unmount SD card in the same menu).
You can copy your media file at any location on the sdcard, the video/music player should find them on the tablet.
Thanks Received: 264
2012/04/04 - 17:43
on my sd card i have a strange issue, when i use`it with my htc phone connected as a usb mass storage the read and write speeds are better compared when it is connected to the arnova in the storage mode
exelletor
Blog Team
Forum Posts: 450
Thanks Received: 30
2012/04/04 - 17:50
Can you may be test it with our Arctools application on your HTC(assuming it runs android) and on your 7c?
Spaceman
Forum Posts: 26
2012/04/04 - 21:49
Hi again,
Thank you exelletor and admin, for your help.
This is what is happening right now, I have inserted my Micro SD card into the Arnova, connected the Arnova to my PC, dragged a video from the PC to SD card, checked it was there and it was, unplugged the Arnova safely, went to the Arnova, opened video player nothing there, went to Files, SD Card, and I have .adobe-digital- editions and .com.mobisystems.editor.office_registered and helex.thumbnails and Digital Editions and eBooks and LOST.DIR and rn-donwloads and nothing else, I searched the whole tablet and I cannot find the video, so I connected the tablet to the PC again, found Arnova, looked under SD card and there was the video, now I don't know what to do!
Can someone help please ๐Ÿ™
Spaceman
Forum Posts: 26
2012/04/04 - 23:19
Hi again,
O.K things are looking a lot better, I removed the card from the Arnova, inserted it in the Micro SD card adapter, inserted it in the PC, dragged a video onto the SD card in Arnova, inserted the card back into the Arnova, went to Video Player and there it was, plays perfectly, I don't know why it didn't do it when I had the Arnova plugged into the PC, but for me this is even better, as I don't have to have the Arnova on when transferring Music and Video files.
Thanks once again for everyone's help ๐Ÿ™‚
iamapc
2012/04/04 - 23:45
I had a problem something like this with my Arnova 7 G2, But found that copy and pasting to "removable" worked although an sd card appeared,Video file would not go on the card but went in removable!!
col2802
Forum Posts: 26
2012/04/23 - 15:10
hi, have just got my 32gb card for my 9g3, inserted it and all seemed fine. If I try to transfer my apps across to it as I have done with my mobile phone, it doesn't allow it. Is this anything to do with showing my 32gb card AND an internal sd card in my storage settings? Looking at what uses what, the internal sd runs most of the tablet files and features so am reluctant to unmount it. I'm running 4.0 ics. It allows me to trannsfer video files to my 32gb card fine, though if I could move apps to it as well, I would be able to keep my system running smoothly without any lag. Cheers
exelletor
Blog Team
Forum Posts: 450
Thanks Received: 30
2012/04/23 - 15:55
As far as I remember, Android 4.0 doesn't have that "move to SD-card feature". If you mean transferring plain apk files to it, you can just transfer them, then go to the settings on your g3, go to Applications -> Development -> Allow applications install from other sources(or something like that).ย
col2802
Forum Posts: 26
2012/04/24 - 07:41
Thanks for your reply, unfortunatly, it doesn't give you that option. In settings, if you go to apps it just shows you which ones you have (running/all etc.). On developer the app options are don't keep activities, background process limit and show all anr's. Do you have any other suggestions I could try?
2012/04/24 - 15:04
On Android 4 ICS, the setting to allow sideloading applications is in Settings / Security / Unknown sources.
Custom firmwares for the Arnova 9 G3 (to be released later)ย will probably allow the system to be partitioned differently, giving more space for the application like it's the case for the Arnova 9 G2 firmwares.
col2802
Forum Posts: 26
2012/04/24 - 16:16
No joy with unknown sources on or off admin, tried it with pre installed angry birds. As you said above, hopefully the software updates should help ๐Ÿ™‚
2012/04/24 - 16:30
did you tried to download the apps in your tablet from internet( tell me a app and i will upload you the app as long it is free ๐Ÿ˜€ ), maybe it works if you download from internet.
col2802
Forum Posts: 26
2012/04/24 - 23:11
Cheers for the offer globula but it would be my paid apps id install, I'll hang slack for the ability to get google play store working, then I'llr it ut and let you know
yojone
Forum Posts: 26
2012/05/23 - 20:31
buenas tengo arnova 10g2, cuandoย inserto microsd exterior no encuentro la sd interna con sus archivos cuando la saco entonces si las dos la nombra sdcar pero solo lee una
hay alguna solucion para poder leer las dos a la vez
gracias ย
Currently Online: teomanfbm
102 Guest(s)
Devices in use: Desktop (92), Phone (9), Tablet (2)
teomanfbm
pawel255
elpacox
Kolokolov Pavel
Ikeman
martn28
