2012/03/28
I just went on the Samsung site went to this card, and there it said:
Will this accessory work with my Product, and in a box next to it I typed:
Archos Arnova 7b G2 and it said
"Your Product is not compatible!
This Accessory is not guaranteed to work with your product"
So then I just typed in Archos and received the same reply, can someone tell me if they are running this card in the same tablet as mine and if it works?
Thanks.
2011/12/27
Spaceman said
Archos Arnova 7b G2 and it said"Your Product is not compatible!
This Accessory is not guaranteed to work with your product"So then I just typed in Archos and received the same reply, can someone tell me if they are running this card in the same tablet as mine and if it works?
Thanks.
dont quote me on this buy i think this card is fine. most sites for some reason dont even register archos/arnova as an official brand they tend to leave it out. i would think that it is just not in the database so returns an incompatible message, i would think it as a "brand not recognized" message
alex
2012/03/28
Thanks for your reply 🙂
It would be nice to know if the Class 10 card would definitely work in my 7b G2, I don't really want to spend £30 on a card and then find out it is not compatible, I could go for a Class 6 but would prefer the Class 10 as it would be more future proof and better for watching films.
Do you think it is worth opening a thread as asking if anyone has tried it?
Spaceman said
Hi,Thanks for your reply 🙂
I don't think it's necessary to open another topic, this one is quite appropriate for discussing about micro sdcard compatibility.
I'll have a look on our Arctools benchmarks if I there are any test data for that Samsung card on an Arnova 7b G2, will let you know.Â
When looking closer at Arctools benchmarks, I found 18 tests using that SDCard model, there were unfortunately no tests run on Arnova G2 in my data, most benchmarks were executed on Archos Gen8 devices (A101IT, A43IT that's exelletor , A70IT).
As exelletor said, there is no reason it shouldn't work on the 7bG2.
2012/03/28
Hi again exelletor,
I hope you can help, I have just received my Samsung 32 GB Micro SD card, can I just put it straight into the tablet?
Also which is the best way to download load films and music, should I plug in Arnova 7b G2 and drag the films/music to the Video/Music folders on the Arnova or to the SD card folder.
One last thing, is it better to use the adapter for the SD card, insert this into my computer, download the films/music onto the SD card, then put the SD card into the Arnova, the only reason I'm asking this is I wanted to know if the card needs to be formatted or I can use it straight away.
Thanks in advance for your help 🙂
57 Guest(s)
Devices in use: Desktop (49), Phone (8)
