2015/07/17
I put the files here: http://www.filedropper.com/flexeliteimagesnotes Let me know if you have any issues getting it.
I am running a test to try and determine if the power drain in standby is a hardware issue that has no chance getting fixed or it is a firmware issue. I have it at the bootloader and disconnected from the USB. This should not have the DDR configured, most likely a low CPU clock setting with one core running, the USB port on, most likely a serial port and the display powered down. I will post the results tomorrow.
Insignia Flex Elite kernel #137, preempt 17 Jun 2015 is now in the archive: http://crewrktablets.arctablet.com/?wpfb_dl=2613
If anyone would like to play around with our AOSP build, just change kernel/resource before flash ...
Ok, is there a mass_storage mode? Does the tab have keys?
Maybe a driver issue. Restart flash modus (with key combination) and do again. Is there also a Reset?
74 Guest(s)
Devices in use: Desktop (65), Phone (9)
tdomnic024
otismaibe
Tsuna77
docentik2006
nechey
