[ ROM ] Tronsmart T428 (1080p kernel) Android 4.2.2 custom root firmware (2013/06/13)
2013/06/17 - 17:32
Here is an Android 4.2.2 Jelly Bean rooted firmware for the Tronsmart T428 quad-core RK3188 MiniPC based on latest official release from 2013/06/13. Kernel display at 1080p.
Build information
Kernel: Linux version 3.0.36+ (root@lhh12-desktop) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #12 SMP PREEMPT Sat Jun 8 21:06:17 CST 2013
Android 4.2.2 JB: rk31sdk-eng 4.2.2 JDQ39 eng.root.20130613.220658 test-keys
  • root with latest SuperSU version 1.32 (free version)
  • Google Play Store fixes so more applications are visible/compatible
  • increased storage space for applications (/data partition) to 3 GB
Download: kasty-tronsmart_t428_1080p-422-20130613_rooted5.zip
Please flash with Rockchip Batch Tool 1.7, use Restore button.
Stock Firmware source: geekbuying.com
cemo, boybadluck, yoga
Radiant311
2013/06/18 - 21:07
I got my T428 rooted with moborobo but I had to close down moborobo before running TPsparkyroot then that let adb.exe do it’s thing without any errors except for the supersu thing which I downloaded later on from google play store. So now what folder do I put the new rom update.img file in with moborobo so that it will ask me to update the firmware?
This is what eric on the geekbuying.com blog said about the situation but I tried it and it didn’t work for me so any ideas on what I should do next?
June 17, 2013 at 2:07 pm
Please try to do this, download the firmware, decompress it, and rename the img file to update.img. copy the update.img to your micro sd card, insert to your Tronsmart t428,and then the t428 will inform you find a new firmware update, click ” update button” and then you will get the new firmware installed.
2013/06/18 - 23:08
The method mentioned by Eric does not work well with custom firmware that have a modified apps storage space (such as the one published in post #1)
As recommended, you should use Rockchip Batch Tool 1.7 to flash the firmware (use Restore button)
We have a rather old tutorial here that will give you the general idea, a more up to date guide for MiniPC and recent tablets is in the works.
You can also refer to geekbuying's instructions:
http://blog.geekbuying.com/index.php/2013/04/28/tronsmart-t428-firmware-upgrade-instruction/
boybadluck
2013/06/19 - 11:04
Thanks for the rooted 1080p firmware. Upgraded but seems lagging caused T428 hard to handle 1080 60p, wireless hard to get connected. Now I'm going back to 720p. This is my experience on 1080 firmware and there is no other error.
cheers
2013/06/19 - 11:12
I'm also not so satisfied with this firmware performance and more generally with other 1080p firmwares as well. I switch back to 720p too Wink
boybadluck
cronofx
2013/06/21 - 01:21
hi ArcTable thank You for support T428 if you have a time could You  modify the kernel so users with tronsmart t428 could overclock theirs devices to 1900 MHZ of course with fan cooling
darqnez
2013/06/26 - 19:14
I am using this rom and FYI HuluPlus and Plex are unable to play video, these worked on previous Roms. Hulu can play the commercials but not the videos and Plex just has black screen when it thinks its playing the videos. Probably a hardware acceleration issue.
61 Guest(s)
Devices in use: Desktop (60), Phone (1)
