[ ROM ] MINIX NEO X7 mini Android 4.2.2 custom root firmware (2013/11/14)
2013/11/17 - 02:02
Here is an Android 4.2.2 Jelly Bean rooted firmware for the MINIX NEO X7mini quad-core MiniPC based on latest Minix release from 2013/11/14
(2013-11-14_box_x7mini_6210.zip / 2013-11-14_box_x7mini_6210.img)
Build information:
Kernel: Linux version 3.0.36+ (root@zhangboyu-desktop) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #351 SMP PREEMPT Thu Nov 14 16:37:52 CST 2013
Android 4.2.2 JB: rk31sdk/rk31sdk/rk31sdk:4.2.2/JDQ39/eng.root.20131108.175115:eng/opinions-on-teclast-p90hdst-keys
  • root with latest SuperSU version 1.69 (free version)
  • increased storage space for applications (/data partition) to 4 GB
  • NEW!  optional ClockworkMod (CWM) Recovery easy install package
Download: kasty-minix_neo_x7_mini-422-20131114-rooted4.zip
Please flash with Rockchip Batch Tool 1.7, use Restore button.
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have a Minix Neo X7mini device to test the custom firmware.
matoos
2013/11/26 - 22:32
matoos said:
Hi admin.
I have just installed the firmware you posted a couploe of days ago...
I would like to say thank you for a good job.:)
You say there that any problems should be passed on.
After the reboot everything seemed to work just fine, but after setting 1080p 50 or 60 hz there is a glitch on screen. Lines and whole screen bounces with a picture from previous views... If I set 24 hz it works ok. It is also working ok if the screen resolution is set to 720p...
Best regards.
Matic
After trying the stock rom the same happens...
Reverting to previous rom.
Bye.
77 Guest(s)
Devices in use: Desktop (67), Phone (10)
cutierogue
