Pipo M6 Pro
My Archos died so I bought a Pipo M6 Pro as it is apparently the best chinese tablet. Fair enough, but its advertised as having an RK3188 chipboard but in settings it shows rk30 .Anybody?
lioneldp
LONDON
2014/05/03 - 23:04
My Archos died so I bought a Pipo M6 Pro as it is apparently the best Chinese tablet. Fair enough, but its advertised as having an RK3188 chipboard but in settings it shows rk30 .RK3066. Seller says he updated it. So how come the chipboard is different .Can the upgrade shown on this site change the chip . rk 30 is dual core but the M6 after upgrade still shows quad core. Also the process is 40nm and not 28 nm as stated. Can the upgrade change this as well. And why would it? Seller says it has to be an rk3188 . Looking at the available update above I already have it. I am confused and so it seems is the seller. He has offered to accept it back. Any ideas please.
2014/05/04 - 03:57
Internally the rk31board is called rk30.
Download CPU Tweaks from Play-Store. How many cores do you see?
lioneldp
LONDON
2014/05/04 - 08:47
Hi,thanks for reply CPU Tweaker says its got 4 processors.  Under cpu 0 its got gov cpu1 has 312 MHz, cpu 2 has n/a underneath and under cpu3 its just got 'times'
How come they can advertise it as 28nm but shows as 40 nm, also on a pic of a Pipo M9 settings it DOES show rk31?
Lionel
2014/05/04 - 09:30
Don't think too much on advertising. Pipo M6 Pro is a very good deal.
JEssicannn
Forum Posts: 252
2019/10/23 - 01:57
41 Guest(s)
Devices in use: Desktop (37), Phone (4)
merlin077
nrod
midnight-gr
Pajaro047
trroll171717
alsoft75
