[ ROM ] Measy U4B Android 4.2.2 custom root firmware (2013/07/18)
kirtg21
Forum Posts: 13
2013/08/28 - 19:09
Flashing thru SDCard probably won't work because of the modified apps storage partition (now 3 GB)
You need to flash with Rockchip Batch Tool 1.7, use Restore button.
It works. Have tried it. How ever Skype does not work on firmware
2013/08/28 - 20:54
qwerty13
2013/12/03 - 23:55
I tried to use this firmware and now my U4B does not work at all :( It just stops during booting proccess and there is black screen with "Android MiniPC" and nothing is happening. What can I do now? I can not open it as I will loose my guarantee. Is there any way to bring it to working state?
rojorojillo
2014/01/19 - 06:37
I have that problem and resolved it by installing the image update in a sd card , doing the uptdate only to have root access and then used the arctools apk to reboot in boatloader  and then used the batch tool when it was recognised by the pc having the usb connection in the stick on.
fiuwe
2014/04/29 - 21:54
Hi all... I have the same problem of @querty13...
do any one know how to solve the situation ? :(
cracktech
Malaysia
Forum Posts: 432
Thanks Received: 112
2014/04/30 - 13:12
I HAVE THE SAME PROBLEM!!
I didnt follow instructions properly and tried to be a smart alex and flash the firmwware through sdcard!
This is typical smart alex mentality we have said many many many times we dont recommend installing through sdcard boot update procoess and yet we still have smart alexssss doing it here and then coming crying (sob,sob,sob) to ask for help. Skype is working properly on this #404 KitaKat firmware as far as I know (NO FC), GPS is also working (although due to hardware limitation the signal is poor not because of firmware)
And NOBODY would recommend flashing a firmware for another model onto another model no matter how similar they are. This just too risky without a proper porting over of firmware.
fiuwe
2014/04/30 - 17:24
   i solve the situation opening the box, along one long side of the board there is a little switch.
Keep it pressed and plug the u4b inside your pc and now it should be visible to any correct version of rkbatchtool.
Then you just need a working fw.
I found the original .244 then I found another working custom rom, but unfortunatly not this one...
If you want send me a PM and I'll give you the address for the other rom.
I do not want to create problem with admins because i do not know if it is allowed to stick other custom rom... :)
paulodiff
2014/07/21 - 09:26
Thanks i've used your tips.
If you cut your Measy U4B you can find a flash button!!!4.2.2
http://i62.tinypic.com/mc422s.jpg
threehappypenguins
2014/08/28 - 21:57
I have an MK809III RK3188 and it has the same information. rk31sdk 4.2.2, kernel is 3.0.36+. Does that mean it's compatible? The Kernel 3.0.36+ says: "3.0.36+ root@lhh12-desktop #59 Sat Jan 18 10:12:18 CST 2014"
kupidi
2015/01/24 - 01:57
hi guys
I am googling from some times now and i dont know what to do since i found your forum, and i thought to register and post, because maybe ill find some answers. (Sorry if this isnt the best place for posting this)
i have a measy U4C and i updated it from 4.2 to 4.4 custom firmware,because i started to have some wifi dropping issues, i dont remember where i got this but its not fully designed for the U4C. Plus it had some other problems with the HD videos and view on the TV. Now i want to downgrade to the stock firmware or to some stock modified firmware like the U4B custom firmware you are talking about in the topic. Please help me with this..
Regard
76 Guest(s)
Devices in use: Desktop (53), Phone (23)
chimo014
vishu bhatnagar
djwood1014
4ipolino
thomashansmuller11
abro
