Here is an Android 4.2.2 Jelly Bean rooted firmware for the Measy U4B quad-core MiniPC based on latest Measy release from 2013/07/18.
Build information:
Kernel: Linux version 3.0.36+ (imtqc@imt-server) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #41 SMP PREEMPT Thu Jul 18 17:25:44 CST 2013
Android 4.2.2 JB: rk31sdk/rk31sdk/rk31sdk:4.2.2/JDQ39/eng.imtqc.20130717.185112:eng/opinions-on-teclast-p90hdst-keys
- root with latest SuperSU version 1.41 (free version)
- increased storage space for applications (/data partition) to 3 GB
Download: kasty-measy_u4b-422-20130718_rooted3.zip
Please flash with Rockchip Batch Tool 1.7, use Restore button.
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have a Measy U4B device to test the custom firmware.
darrellr, danmckinley, and2me If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
Flashing thru SDCard probably won't work because of the modified apps storage partition (now 3 GB)
You need to flash with Rockchip Batch Tool 1.7, use Restore button.
baryl88 If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/07/28
Here is an Android 4.2.2 Jelly Bean rooted firmware for the Measy U4B quad-core MiniPC based on latest Measy release from 2013/07/18.Please report any problem with this firmware, I can't verify this custom firmware works as I don't have a Measy U4B device to test the custom firmware.
I can confirm this works fine. Bluetooth keyboard finally working okay and wireless not dropping (yet!).
What it doesn't do is read my 64gb exfat formated SDXC chip. Can you add exFAT support? (https://github.com/rxrz/exfat-nofuse)
2013/07/28
The method I used to update my U4B was to short out one of the pins as described here
No, you don`t need to dismember the tablet.
Read this to learn more about your tablet.
http://www.arctablet.com/blog/forum/archos-arnova-general/possible-fixes-and-repair-methods-for-your-rockchip-tablet/
2013/08/03
globula_neagra said
No, you don`t need to dismember the tablet.Read this to learn more about your tablet.
Measy U4B haven't any buttons (ie recovery, power, reset etc) and in order to get to the FLASHING mode, need to short pins inside of device.
http://blog.geekbuying.com/index.php/2013/06/09/measy-u4b-quad-core-tv-stick-android-4-2-stock-firmware/#.Uepl1W37qTQ
So, if not, please tell me how to flash it w/o disassembling.
Did you had a look here ?
There are at least 2 alternative methods to get the tablet in flashing mode if none works, that means that you need to open the Mini Pc.
2013/08/03
This firmware can be flashed from SD. I have tried it and result was OK.
One important point - during the flashing process I used external power adapter from Nexus 4 (5V / 1,2A).
2 globula_neagra: Yes I've done it. But adb method doesn't work for me due to "adb device" returns empty list of attached devices.
2012/12/26
I'm sorry I use a translator. After a week of trouble-free operation device freezes, pulled out of the socket and after the boot hangs inscription Android MiNi PC download is going on. What should I do to re-sew or have a way to spice up?
Простите пользуюсь переводчиком. После недели бесперебойной работы девайс завис, выдернул из розетки и после включения при загрузке висит надпись Android MiNi PC дальше загрузка не идет. Что делать, заново прошивать или есть способ оживить?
Currently Online: Skyph
64 Guest(s)
Devices in use: Desktop (57), Phone (8)
lilila3
Anatrop
antoniors021
wemiy54158
sidor
houssmen
