[ ROM ] iMito QX1 Android 4.2.2 custom root firmware (2013/06/07)
2013/06/08 - 17:16
Here is an Android 4.2.2 Jelly Bean rooted firmware for the iMito QX1 quad-core RK3188 MiniPC based on latest release from 2013/06/07. Kernel display at 720p.
(iMito_QX1_V422_130607.rar)
 iMito_QX1_20130604_home.pngImage Enlarger
Build information
Kernel: Linux version 3.0.36+ (gouwa@lurk) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #54 SMP PREEMPT Fri Jun 7 19:23:59 CST 2013
Android 4.2.2 JB: rk31sdk/rk31sdk/rk31sdk:4.2.2/JDQ39/eng.gouwa.20130604.102259:eng/opinions-on-teclast-p90hdst-keys
  • root with latest SuperSU version 1.32 (free version)
  • increased storage space for applications (/data partition) to 2 GB
Download: kasty-imito_qx1-422-20130607-rooted6.zip
Please flash with Rockchip Batch Tool 1.6, use Restore button.
Please report any problem with this firmware, I verified this firmware boots on the Tronsmart T428, but I don't have an iMito QX1 to fully test the custom firmware.
Stock firmware source: geekbuying.com
civicscootin
intheknow
2013/06/13 - 05:15
What happened to my reply I posted? What gives?
2013/06/13 - 09:40
I don't know if it's not there it probably hasn't been saved, I'm afraid you'll have to post again.
dezz
2013/06/23 - 06:51
Thanks for the rom, work like a charm
j0hnj0hn2
2013/06/27 - 12:17
Would be nice to have the android 4.2.2 1080p root firmware for the Imito QX1
dCY
2013/06/27 - 23:56
Yeah, kinda still waiting for it. till now only 720p is out.
2013/07/03 - 11:47
I'm taking note of your queries, I should soon post a 1080p firmware Android 4.2 firmware for the iMito QX1.
intheknow
2013/07/06 - 05:47
I have the Imito QX1 mini PC and the thread author stated "Please report any problem with this firmware, I verified this firmware boots on the Tronsmart T428, but I don't have an iMito QX1 to fully test the custom firmware." My 1st question is does this 4.2.2 720p rom work on the iMito QX1? Can this 4.2.2 720p rom version be updated from the micro sd memory card in the iMito QX1? I do not have access to a windows computer for doing the update through widows. I purchased the iMito QX1 so I did not have to use a Windows computer. What would it take to be able to install this rom from a Micro SD card? Didn't Geekbuying.com use to have the Official roms that could be installed from a micro SD card? Does this 4.2.2 720p rom able to use powered USB Hub? The 4.1.1 rom that came installed in my iMito QX1 stick does not handle powered USB Hub. I wish I would have purchased the CX-919 mini PC. At least that device works good and finless at freaktap.com is developing a new rom version for the iMito QX1. Thank you for the information.
Thanks Received: 264
2013/07/06 - 12:02
The update from sdcard can be applied only if the partition layout is not changed, but this firmware has an increased data partition, and it is a risk of resulting a boot loop.
The firmware can be flashed also via Linux, but there are many commands to push towards the device.
ossee
2013/07/08 - 12:51
When I connect my QX1 to my USB-port (Windows 7 x64), load the update.img into the Rockchip Batch Tool, and press restore it gives an error (see attachment)
Error.pngImage Enlarger
Does anyone know what I'm doing wrong? Thanks in advance,
Ossee
2013/07/08 - 13:01
Try to press Switch button and see if the square turn Green, then you can press Restore button.
ossee
ossee
2013/07/08 - 13:14
Thanks for your quick response!
I tried to press Switch which seemed to be successful, however, the square did not become green. The only thing it did was disconnecting the device (at least I heard that sound)
Error2.pngImage Enlarger
Are there any other options? Thanks!
Ossee
2013/07/08 - 14:05
If you never flash firmware using Rockchip Batch Tool before, you'll need to install drivers that ship with the tool. Windows probably asked from them after you pressed the Switch button, check in your Windows notification try for driver installation.
We also have a small troubleshooting guide here:
ossee
2013/07/08 - 16:58
The main question is if he has got the tablet in flashing mode
The pink square appears usually when the tablet is booted normally, therefore, make sure that you get the tablet in flashing mode (NO IMAGE ON THE SCREEN OF THE TABLET AND A POP-UP NOTIFICATION WINDOW ON THE PC REGARDING DRIVERS = FLASHING MODE)
ossee
2013/07/08 - 17:33
Everything works like a charm now :D
There is only one issue, the internal storage for my apps is still 0.89GB instead of 2GB. Which firmware package I should flash, since there are two? Thanks a lot!
Ossee
82 Guest(s)
Devices in use: Desktop (58), Phone (24)
Kaka88
Donalbert
halum
BlackCero044
BlackCero04
taylordahmer
