HOW TO FLASH MEASY U4B WITHOUT OPENING DEVICE
kirtg21
Forum Posts: 13
2013/08/28 - 07:53
Opps thanks. will try the steps that admin suggested and come back.
measy has only 1 usb 2 port and 1 micro usb port.
will try to connect with either and do the steps as mentioned in post 8 and come back and update.
Globula / admin ... u guys rock ! would not have gone this far without ur support.
thanks
kirtg21
Forum Posts: 13
2013/08/28 - 19:02
Funny but true for measy u4b.
None of the methods of post 8 worked. Neither the arctool app .. Neither changing storage mode and then clicking USB . it just goes purple. And then when I click on switch ... It just hangs the device and device switches off.
Finally we try what I try is not going to help. Just put the image file of kasty firmware in a micro USB. Amazingly it recognises upgrade . believed it or not .. Mine is a stock firmware. I simple click upgrade and it upgrades the firmware to a rooted and better one. Just 2 min work. That's it.
So basically none of the methods worked except ... Simply putting the IMG file in a micro USB slot . and it did the magic.
2013/08/28 - 20:54
There's no magic here, you just flashed the firmware using the method we don't recommend.
Just copying the image.img file to the root of the internal storage or the sdcard actually triggers the firmware update process, that's how Rockchip based devices work since years. However this method doesn't fully erase the device after flashing nor it uses the partition modification that we apply to offer the extended storage space for applications (from 2GB to 4GB depending on the devices) See screenshot below:
iMito_QX1_20130604_2GB_storage_apps.pngImage Enlarger
About the device "rebooting" to a black screen after you push the Switch button when the square in Rockchip Batch Tool is purple, that's the normal behavior. After that, your computer should start installing the Rockchip drivers. If it doesn't there's something wrong, you may find some help in the Troubleshooting section of our Rockchip flashing guide.
kirtg21
Forum Posts: 13
2013/08/28 - 21:15
Thanks . that is good explanation.
Coming to the point of Skype using the custom firmware... Is there any particular version we should download . have installed Skype from the market and the call simply does not connect.
Cam : Logitech .
Firmware: custom kasty
Can u please advice further on this.
kirtg21
Forum Posts: 13
2013/08/30 - 15:34
hey guys
tried a lot on post number 8 .
steps done so far
1) using rk batch tools 1.7 in administor mode.
2) have swtiched on storage to mass .
3) measy device is getting detected
4) have installed drivers
5) device gets charge on micro usb slot .
6) have connected a USB male to male - to the computer for data transfer and rock chip tools functioning.
7) device getting detected but box is showing PURPLE.
8) while trying to SWITCH .. the device just turns off.
9) DISPLAY SHOWS " check input device... no signal "
have tried a hell of a lot of times in multiple ways but the damn PURPLE just doesnt turn GREEN.
can u please help . desperate now.
thanks a ton
kam.76
2013/11/06 - 15:19
Hi all.
I'm facing the same problem as kirtg21 wrote above.
Did anybody find solution?
rojorojillo
62 Guest(s)
Devices in use: Desktop (56), Phone (5), Tablet (1)
yuuma
dima1965
Денисен88
Romanmob
reisender_androit
callmemax
