HOW TO FLASH MEASY U4B WITHOUT OPENING DEVICE
kirtg21
Forum Posts: 13
2013/08/27 - 07:53
have heard of fast bootloader method . am sure its a great device and we need to demystify this bit. All members kindly contribute your bit.
thanks
Thanks Received: 264
2013/08/27 - 11:54
Here you can find ways to get the device in flashing mode.
http://www.arctablet.com/blog/forum/archos-arnova-general/possible-fixes-and-repair-methods-for-your-rockchip-tablet/
Flashing methods would be using rockchip tools in windows, and lin linux, rkflashtool.
kirtg21
Forum Posts: 13
2013/08/27 - 12:27
the archos tablet way does not really work for measy u4b.
problems as follows :
1) device not getting detected on windows 7
2) no real tool to get device into fastboot mode.
if there are any possible ways .. pl enlighten
Thanks Received: 3170
2013/08/27 - 12:30
On your Windows computer, does Rockchip Batch tool show a Purple color square when the Measy U4B is connected thru USB ?
kirtg21
Forum Posts: 13
2013/08/27 - 13:09
No it does not. Actually it does not even detect the tablet .
  1. Have going into measy settings and there is an option in measy under USB to enable it to connect to computer. Have even done this.
  2. The measy is connected from its micro usb slot into the usb slot of the computer . hope I am doing it the right way.
  3. have tried using Rockchip batch tool 6 as well as 7 .- but no luck .
only if the device is detected can one install the drivers as drivers are in .sys format file. so windows needs to detect the device which it is currently not doing.
any thoughts ?
2013/08/27 - 13:37
Well, first you need to get the device in flashing mode, install the drivers and then you should get a reaction.
You can download and install our app
http://www.arctablet.com/assets/tools/arctools/com.arctablet.arctools.apk
Which has an option to reboot in bootlader (flashing mode)
After which you are supposed to connect it to the pc, install usb drivers and check in rockchip batch tool if the device is connected.
kirtg21
Forum Posts: 13
2013/08/27 - 13:47
thank you . you have been very kind. i shall try this and update status shortly.
is there any particular firmware for measy u4b which does the below.
1) supports skype
2) should be rooted .
3) supports game loft
4) has rk mirror/ supports rk remote etc
which firmware will you recommend ?
2013/08/27 - 14:48
On top of my head, to put your MiniPC in flash mode required for Rockchip Batch Tool:
- if your miniPC has 2 microUSB connectors, plug your computer to the microUSB connector that the MiniPC uses to mount data on the computer
- on the MiniPC, go Settings / Storage then the menu icon in the top right corner, change the choice to Mass Storage
- then go to Setttings / USB and check the box "Connect to PC"
- on your Windows computer, Rockchip square should turn Purple, press Switch button, the square should turn Green, you are ready to flash.
Our custom firmware is rooted, it should support Skype and has rk remote support. There is no special support for Gameloft games, I can't confirm they'll install/run.
kirtg21
kirtg21
Forum Posts: 13
2013/08/27 - 19:40
Hi there.
Update as follows on measy u4b
Installed arc tools 0.80 version.
Also have downloaded custom ROM and kept ready.
While running arc tool app  on measy u4b and selecting reboot bootloader... Application just hangs.
After a while it gives the message of app not responding. Basically it does not reboot with any option.
Did this test on my Samsung galaxy s3.. And opened arc tools app and tried the reboot boot loader and it very neatly rebooted in download mode.
What cud be the possible reason for measy .
Kindly help.
kirtg21
Forum Posts: 13
2013/08/27 - 19:47
Now I have tried the app arc tools with 2 measy . ( my friends piece ) ... Same result. App just hangs after clicking reboot boot loader.
Also tried on lg optimus . viola it works. :)
2013/08/27 - 20:11
It might be disabled from the firmware that function.
Try what admin suggested.
kirtg21
kirtg21
Forum Posts: 13
2013/08/27 - 20:41
Am sorry . tried looking for the Admin post. Am a little new around here.
Can u please repost this . a thousand thanks .
kjain
2013/08/27 - 21:01
I am having the same issue as Kirtg21 Tried arc tools 0.80 version No luck :( .
2013/08/27 - 21:19
it is the 8th post from this topic :)
2013/08/27 - 22:05
As globula mentioned, the method from post #8 is preferred.
ArcTools reboot functions won't work on non rooted firmware, which is probably the case if you still run the default firmware.
101 Guest(s)
Devices in use: Desktop (86), Phone (14), Tablet (1)
fantom0308
Morris028
robertgdfdgdfss
wtf
jdani20001027
thinkappleeight
