2013/12/01
I purchased a mini pc tv cloud stick all is states is quad core rk3188 1.6 cortex A9 / cx 919II
The vendor sent me this file for updating with rockchip update tool. I don't want to install as not sure what rom this is and if it has google apps. Does anyone know what this rom is or if google apps are included and rootable? I just dare not risk it. Also does anyone know of a rom that will work fine with my stick with 1080p, root and overclocking kernel? Also can not understand why my cpu seems locked at 1ghz. anyone have any ideas? Thanks guys. :0)
cyxtech_rk31 J22 140424_8G2G.rar
Not much to say:
cyxtech_rk31_809III_8089_140424_8G2G
2nd gen loader JB firmware
ro.build.display.id=rk31sdk-user 4.2.2 JDQ39 user.arron.20140424.151002 test-keys
ro.vendor.sw.version=RK3188_R-BOX_ANDROID4.2.2-SDK_V1.0.0_130514
kernel aaron #160 preempt 20140424
no Play-Store
2013/12/01
Not much to say:cyxtech_rk31_809III_8089_140424_8G2G
ro.vendor.sw.version=RK3188_R-BOX_ANDROID4.2.2-SDK_V1.0.0_130514kernel aaron #160 preempt 20140424
no Play-Store
Thank you Oma
So is this no better than whats pre installed. I just can't even use this with 720p I have to use even lower res or I get constant blinking. Any Idea why its only showing 1ghz cpu its supposed to be 1.8ghz? That's crap with no playstore. stupid vendor. I need a good 1080p kernel and rom rooted with playstore for cx 919II anyone know of anything yet for this stick?
2013/12/01
My kernel shows 3.0.36+ server #122
arron@develop-server 122
mon feb 10 14.08.19 cst 2014
build number rk31sdk-user 4.2.2 jdq39 user.aron.20140210.151002 test keys
vendor version
rk3188_r-box_android4.2.2-sdk_v1.0.0_130514
So no point flashing the above rom but will kernel be better I wonder?
So, the firmware in post #1 is a later one. Possibly a bug fix.
Sorry to butt in like this but regarding "upping" the kernel to 1.8Ghz OMA is the Guru here only he can tell whether that is possible. I only want to comment regarding Rooting of  JB RK3188 to use "DANS Root script" Google for it. I have managaed to root my original factory ROM for my PiPo M9Pro Rk3188 cleanly before I came across Archtablet Forum with its prerooted firmware for that model.
All itneeds are ADB drivers and RK USB drivers installed on PC then you are good to go.
About Me  LENOVO S939 MTK6592 Vibe 2.0 - 1507,LENOVO A8-A5500 KitKat MTK8382 S029,Lenovo Tab2 A7-30HC MT8382 Lollipop,LENOVO A880 S027 MTK6582 (JB),ONDA V975m V3 AMLOGIC M802 (KitKat), PiPo M9Pro RK3188 KASTY ROM (KitKat # 407 Mod), ZENITHINK ZTPAD:C93 Duo Core AMX CM10.2_rc-3, Z102 And. 4.0.4, C91 And. 4.0.4,AIGO M60 Android 4.04 6" A13 (rooted).Lenovo A369i 4.2.2 S011 ROW
2013/12/01
So, the firmware in post #1 is a later one. Possibly a bug fix.- Oma -
Thanks Oma tempted to try it but its no good without google apps play-store. Unless I can get google play-store on it I don't want to try it.
The rom it came with is pretty useless can't go above 1ghz or even run at 720p without hdmi blinking. I really need help!
2013/12/01
cracktech said
Sorry to butt in like this but regarding "upping" the kernel to 1.8Ghz OMA is the Guru here only he can tell whether that is possible. I only want to comment regarding Rooting of  JB RK3188 to use "DANS Root script" Google for it. I have managaed to root my original factory ROM for my PiPo M9Pro Rk3188 cleanly before I came across Archtablet Forum with its prerooted firmware for that model.All itneeds are ADB drivers and RK USB drivers installed on PC then you are good to go.
Yes I rooted the device real easy was not a problem at all.
64 Guest(s)
Devices in use: Desktop (53), Phone (11)
country822
vovandolgan
kenjakenjavitis
Vugare
3nf
lesfurets
