Here is an Android 4.2.2 Jelly Bean rooted firmware for the CX919 quad-core RK3188 MiniPC based on latest release from 2013/07/30. Kernel display at 1080p.
(CX919-RK3188-4.2-1080P.rar)
Build information
Kernel: Linux version 3.0.36+ (root@robin) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #79 SMP PREEMPT Tue Jul 30 10:08:24 CST 2013
Android 4.2.2 JB: rk31sdk/rk31sdk/rk31sdk:4.2.2/JDQ39/eng.root.20130730.100828:eng/opinions-on-teclast-p90hdst-keys
- root with latest SuperSU version 1.51 (free version)
- Google Play Store fixes so more applications are visible/compatible
- increased storage space for applications (/data partition) to 3 GB
Download: kasty-cx919_1080p-422-20130730_rooted3.zip
Please flash with Rockchip Batch Tool 1.7, use Restore button.
Stock Firmware source: geekbuying.com
2013/08/13
Tested with CX=919
OS scaled to 1080P and scaling works.
Pros:
1. Very fast I/O speed (apps download and install quickly)
2. Wifi and BT work well
Cons:
1. Text appears fuzzy and small even when reducing resolution to 720P
2. Slight stutter streaming 720P videos from XBMC (12.2)
3. Significant stutter playing 1080P video (Blu-Ray rip)
4. Hulu Plus crashes and/or plays on audio
5. Stick moderately warm to the touch
6. Slight lag in UI when navigating through home screens, opening apps, etc.
Antutu benchmark score = 14497
smithmal
2013/06/09
How does netflix run? When you say 1080p stutters. Is this on a streaming video? Can you write to any external sd/usb devices? How big is the partiton for apps? Can cwm be installed. If I dont hear back. Il try to catch you over at FT. If not Im gona flash it and answer some of these questions here and at FT. I think I read somewhere where it is 3gb for apps. But not sure. But that question is important for me and if I can link or move apps to sd. Il try the bt too with a simple ear piece. Its all I have at the moment. God it would be nice if all this worked. hmmm Forgot about scipts initD. Will check..Thanks
It is in the first post
Currently Online: vonkarayan, astosenix
64 Guest(s)
Devices in use: Desktop (59), Phone (7)
grielgryel
klaus1255
neverever007
favorit
Альфвоф
kevbez
