[ ROM ] Minix Neo X5 mini Android 4.2.2 custom root firmware 720p and 1080p (version 004 2014/03/11)
2014/04/05 - 13:40
Here is an Android 4.2.2 Jelly Bean rooted firmware for the Minix Neo X5 mini based on latest Minix official release version 004 published on 2014/03/11. This update is available in two versions, one with a 720p and another 1080p display.
(720p kernel: NEO_X5mini_20140311.rar / X5mini_20140311.img)
(1080p kernel: X5mini_20140311_1080fb.rar / X5mini_20140311_1080fb.img)
Official firmware revision history:
MINIX NEO X5mini 20140311 (version 004) 4.2.2 firmware Release Date: 2014-03-11
Change log:
1.) System status bar is hidden by default (call it out either by 1.)dragging up with a mouse;
or 2.)long pressing the menu key of the IR remote);
2.) Battery level modified to 100%;
3.) Fixed IR remote wake-up bug;
4.) New boot screen;
5.) Preloaded XBMC for MINIX edition, Skype and CloudTV;
6.) Added screensaver feature;
7.) Optimized webcam picture taking performance;
8.) New set of NEO A2 airmouse logic, REWIND/PLAY/FF keys remapped to Android standard;
9.) Increased DDR performance;
10.) Default screen scale modified to 100% (full screen);
Build information:
(720p) Kernel:  @Linux version 3.0.36+ (zeng@ubuntu) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #220 SMP PREEMPT Tue Mar 11 14:39:09 CST 2014
(1080p) Kernel: Linux version 3.0.36+ (zeng@ubuntu) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #221 SMP PREEMPT Tue Mar 11 14:46:27 CST 2014
Android 4.2.2 JB: rk30sdk/rk30sdk/rk30sdk:4.2.2/JDQ39/eng.zeng.20140220.175600:eng/opinions-on-teclast-p90hdst-keys
  • root with latest SuperSU version 1.94 (free version)
  • increased storage space for applications (/data partition) to 4 GB
  • NEW!  optional ClockworkMod (CWM) Recovery easy install package
Notes:
Download:
(720p kernel) kasty-minix_neo_x5_mini-422-004_20140311-rooted3.zip
(1080p kernel) kasty-minix_neo_x5_mini-422-004_20140311_1080p-rooted3.zip
Please flash with Rockchip Batch Tool 1.7, use Restore button.
Please report any problem with this firmware, I can't verify this custom firmware works as I don't have a Minix Neo X5 mini device to test the custom firmware.
If you like our work, please support us to keep the site alive and contribute to our efforts.
emanpost, elpollodiablo, horstvogel, lucasno1, nicaroxo
jaby
2014/04/06 - 19:44
Thanks for your excellent Job!!!!!!!!!
sergisat
2014/04/06 - 21:43
Thanks, I posted in minix forum with a link to here.
Thanks again.
Minix X5 mini
sergisat
2014/04/08 - 17:05
Flashed and works like a charm!!!
Installed beyond xbmc 3.3 and working very stable.
Minix X5 mini
horstvogel
2014/04/23 - 14:47
Hallo , I just Try the 1080p kernel. Maybe there is on bug??
If you start the box from sleep modus, Google or the normal Mail app is not working. Is spinning all the time.  You have to reboot every time, if you want to use these Apps.
The original firmeware from MINIX has not this problem.
but 1080p is working fine!!!!-:)
I try this Image.
Thanks Horst
Edit:
Now I try the (720p kernel: NEO_X5mini_20140311.rar / X5mini_20140311.img) Image, there is no problem with Google mail and the normal mail app. After this I go back to the 1080p firmware and the mail App only working after a reboot, not after wake up from sleep modus
lucasno1
2014/04/29 - 17:59
Thanks for your work on the rom.
I have flashed my X5mini with the 720p kernel and it seems good, stable and quick.
However I have an issue where Netflix will not load videos, I can install it, log in and browse just fine, then when I try to play anything it doesn't go past the red Netflix loading page. The app doesn't crash, i can still go back and browse or exit but it wont actually play anything.
Going to try the 1080p version now to see if it's the same but if anyone has an idea it would be appreciated.
Update: 1080p version the same, netflix does not load videos. Going to try the latest official and see if I can get somewhere
Ta
acy
2014/07/01 - 15:00
Hey there! This is the best rom I could find for the X5mini so far...
I modified /etc/wifi/wpa_supplicant.conf (added my wifi passwords etc.), repacked your rom and flashed. Now it can't connect to my wifi network anymore. I think DHCP is failing.
Any ideas how this could happen or what I could have done wrong?
talroze
2014/12/29 - 08:04
Great ROM,
I have just downloaded the 1080 and it is just awsom ,thank you for your hard work.
But i have a small issue,
The remote control app that i installed on my phone cant control the device now,
IS there any way to restore this feature [i realy need it because its the only way i can connect to different fields at the browser]
Thank you very much for your work.
papagaio44
2015/03/03 - 11:39
How can I disable "System status bar is hidden by default".?
lvt213
2015/09/07 - 05:38
Dear All,
Which location(when i unpack img file) i can change the logo boot ?
lvt213
2015/09/09 - 11:47
Dear,
I customize my bootanimation for minix 5 but it boot to black screen instead.
I do not know why.
55 Guest(s)
Devices in use: Desktop (47), Phone (8)
