mini pc GOclever nanoDroid X2 rk3066
hi ... is my first post .... I need help to add bluetouch dougle USB... tanks
nanoDroidx2
2014/12/02 - 20:18
Rockchip Rk30sdk
System (Android 4.1.1)
Model rk30sdk
Manufacturer rockchip
Device rk30sdk
Product rk30sdk
Brand rk30sdk
Android Version 4.1.1 (Jelly Bean)
API Level 16
Build ID JRO03H
Fingerprint rk30sdk/rk30sdk/rk30sdk:4.1.1/JRO03H/eng.mark.20121230.180820:eng/test-keys
Display (1280x672)
Size 1280x672
Refresh Rate 61,9 Hz
Default Orientation Landscape
Physical Size 56,92" (144,57 cm)
Logical Size Large
Density 160 dpi (Medium)
Pixels Per Inch X: 25,4; Y: 25,4
Processor (ARMv7)
Processor ARMv7 Processor rev 0 (v7l)
Cores 2
Max Frequency 1608 Mhz
Instruction Sets armeabi-v7a, armeabi
SIMD Instructions NEON
Memory (881 MB)
System RAM 881 MB
JVM Max Memory 80 MB
Internal Storage 1007 MB
External Storage 1704 MB (Removable)
OpenGL 1.1 (Mali-400 MP)
General
Renderer Mali-400 MP
Version OpenGL ES-CM 1.1
Vendor ARM
Limits
Texture Size 4096x4096
Texture Units 8
Viewport Size 4096x4096
Modelview Stack Depth 32
Projection Stack Depth 32
Texture Stack Depth 32
Lights 8
Compressed Texture Formats
ETC1, Paletted
Extensions
GL_EXT_debug_marker GL_OES_byte_coordinates GL_OES_fixed_point GL_OES_single_precision GL_OES_matrix_get GL_OES_read_format GL_OES_compressed_paletted_texture GL_OES_point_size_array GL_OES_point_sprite GL_OES_texture_npot GL_OES_query_matrix GL_OES_matrix_palette GL_OES_extended_matrix_palette GL_OES_compressed_ETC1_RGB8_texture GL_OES_EGL_image GL_OES_draw_texture GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_OES_framebuffer_object GL_OES_stencil8 GL_OES_depth24 GL_ARM_rgba8 GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_OES_texture_cube_map GL_EXT_discard_framebuffer GL_EXT_robustness
OpenGL 2.0 (Mali-400 MP)
General
Version OpenGL ES 2.0
Vendor ARM
GLSL Version OpenGL ES GLSL ES 1.00
Limits
Texture Units 8
Vertex Textures 0
Combined Textures 8
Renderbuffer Size 4096x4096
Cubemap Size 1024x1024
Vertex Attributes 16
Vertex Uniforms 256
Varying Vectors 12
Fragment Uniforms 256
Vertex Numeric Precision
Int [-2^24, 2^24]
Float [-2^127, 2^127], 2^-23
Fragment Numeric Precision
Low Int [-2^11, 2^11]
Medium Int [-2^11, 2^11]
High Int Not available
Low Float [-2^15, 2^15], 2^-10
Medium Float [-2^15, 2^15], 2^-10
High Float Not available
ETC1
Extensions
GL_EXT_debug_marker GL_OES_texture_npot GL_OES_compressed_ETC1_RGB8_texture GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_depth24 GL_ARM_rgba8 GL_ARM_mali_shader_binary GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_EXT_blend_minmax GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_EXT_discard_framebuffer GL_OES_get_program_binary GL_ARM_mali_program_binary GL_EXT_shader_texture_lod GL_EXT_robustness
Graphic Modes (RGBA 32bit)
RGB 16bit (565)
RGB 16bit (565), Depth 24bit, Stencil 8bit
RGB 16bit (565), Depth 24bit, Stencil 8bit, Samples x4
RGB 16bit (565), Depth 24bit, Stencil 8bit, Samples x16, Non-Conformant
RGBA 16bit (5551), Depth 24bit, Stencil 8bit
RGBA 16bit (5551), Depth 24bit, Stencil 8bit, Samples x4
RGBA 16bit (5551), Depth 24bit, Stencil 8bit, Samples x16, Non-Conformant
RGBA 16bit (4444), Depth 24bit, Stencil 8bit
RGBA 16bit (4444), Depth 24bit, Stencil 8bit, Samples x4
RGBA 16bit (4444), Depth 24bit, Stencil 8bit, Samples x16, Non-Conformant
RGB 32bit (888)
RGB 32bit (888), Depth 24bit
RGB 32bit (888), Depth 24bit, Stencil 8bit
RGBA 32bit (8888)
RGBA 32bit (8888), Depth 24bit, Stencil 8bit
RGBA 32bit (8888), Depth 24bit, Stencil 8bit, Samples x4
RGBA 32bit (8888), Depth 24bit, Stencil 8bit, Samples x16, Non-Conformant
Sensors (7)
Memsart Virtual Accelerometer
Vendor Memsart Corporation
Range 19.6133 m/s²
Resolution 0.001 m/s²
Power 1.0 mA
Delay 200 μs
Memsart Virtual Gyroscope
Range 34.906586 rad/s
Resolution 0.0012217305 rad/s
Power 6.1 mA
Delay 200 μs
Rotation Vector Sensor
Vendor Google Inc.
Range 1.0
Resolution 5.9604645E-8
Power 7.1 mA
Delay 200 μs
Gravity Sensor
Vendor Google Inc.
Range 19.6133 m/s²
Power 7.1 mA
Delay 200 μs
Linear Acceleration Sensor
Vendor Google Inc.
Range 19.6133 m/s²
Power 7.1 mA
Delay 200 μs
Orientation Sensor
Vendor Google Inc.
Range 360.0°
Resolution 0.00390625°
Power 7.1 mA
Delay 200 μs
Corrected Gyroscope Sensor
Vendor Google Inc.
Power 7.1 mA
Delay 200 μs
Codecs (42)
OMX.rk.video_decoder.avc
Media type: video/avc
Color Formats: YUV420SemiPlanar
Profiles: Baseline (1), Baseline (1b), Baseline (11), Baseline (12), Baseline (13), Baseline (2), Baseline (21), Baseline (22), Baseline (3), Baseline (31), Baseline (32), Baseline (4), Baseline (41), Baseline (42), Baseline (5), Baseline (51), Baseline (Unknown), Main (1), Main (1b), Main (11), Main (12), Main (13), Main (2), Main (21), Main (22), Main (3), Main (31), Main (32), Main (4), Main (41), Main (42), Main (5), Main (51), Main (Unknown), Extended (1), Extended (1b), Extended (11), Extended (12), Extended (13), Extended (2), Extended (21), Extended (22), Extended (3), Extended (31), Extended (32), Extended (4), Extended (41), Extended (42), Extended (5), Extended (51), Extended (Unknown), High (1), High (1b), High (11), High (12), High (13), High (2), High (21), High (22), High (3), High (31), High (32), High (4), High (41), High (42), High (5), High (51), High (Unknown)
OMX.rk.video_decoder.vpx
Media type: video/x-vnd.on2.vp8
OMX.rk.video_decoder.h263
Media type: video/3gpp
Profiles: Baseline (10), Baseline (20), Baseline (30), Baseline (45), ISWV2 (10), ISWV2 (20), ISWV2 (30), ISWV2 (45)
OMX.rk.video_decoder.m4v
Media type: video/mp4v-es
Profiles: Simple (0), Simple (0b), Simple (1), Simple (2), Simple (3)
OMX.google.amrnb.decoder
Media type: audio/3gpp
OMX.google.amrwb.decoder
Media type: audio/amr-wb
OMX.google.aac.decoder
Media type: audio/mp4a-latm
OMX.google.g711.alaw.decoder
Media type: audio/g711-alaw
OMX.google.g711.mlaw.decoder
Media type: audio/g711-mlaw
OMX.google.vorbis.decoder
Media type: audio/vorbis
OMX.rk.video_encoder.vpx
Profiles: Main (Version0), Main (Version1), Main (Version2), Main (Version3), Main (Unknown VP8 Level), Main (Unknown VP8 Level), Main (Unknown VP8 Level), Main (Unknown VP8 Level), Main (Unknown VP8 Level), Main (Unknown VP8 Level), Main (Unknown VP8 Level), Main (Unknown VP8 Level), Main (Unknown VP8 Level), Main (Unknown VP8 Level), Main (Unknown VP8 Level), Main (Unknown VP8 Level)
OMX.google.h263.encoder
Color Formats: YUV420Planar, YUV420SemiPlanar
Profiles: Baseline (45)
OMX.google.mpeg4.encoder
Profiles: Core (2)
OMX.google.amrnb.encoder
OMX.google.amrwb.encoder
OMX.google.aac.encoder
OMX.google.flac.encoder
Media type: audio/flac
AACEncoder
AVCEncoder
OMX.rk.video_encoder.avc
OMX.google.raw.decoder
Media type: audio/raw
OMX.google.mp3.decoder
Media type: audio/mpeg
DTSDecoder
Media type: audio/vnd.dts.hd
WMADecoder
Media type: audio/x-ms-wma
WMAPRODecoder
Media type: audio/x-ms-wmapro
AC3Decoder
Media type: audio/x-ms-ac3
RADecoder
Media type: audio/vnd.rn-realaudio
FLACDecoder
WAVDecoder
Media type: audio/wav
AVCDecoder
AVCDecoder_FLASH
AACDecoder
AACDecoder_MIRRORING
RVDecoder
Media type: video/vnd.rn-realvideo
FLVDecoder
Media type: video/flv
M2VDecoder
Media type: video/mp2
VC1Decoder
Media type: video/vc1
M4vH263Decoder
M4vH263Decoder
M4vH263Decoder
Media type: video/mjpeg
VPXDecoder
VPXDecoder
Media type: video/vp6
Features (24)
Graphics
OpenGL 2.0
Android Hardware
android.hardware.bluetooth
android.hardware.camera
android.hardware.camera.autofocus
android.hardware.camera.flash
android.hardware.camera.front
android.hardware.ethernet
android.hardware.faketouch
android.hardware.location
android.hardware.location.gps
android.hardware.location.network
android.hardware.microphone
android.hardware.screen.landscape
android.hardware.screen.portrait
android.hardware.sensor.accelerometer
android.hardware.touchscreen
android.hardware.touchscreen.multitouch
android.hardware.usb.accessory
android.hardware.wifi
Android Settings
android.settings.battery
android.settings.location
Android Software
android.software.live_wallpaper
android.software.pppoe
Google
com.google.android.feature.GOOGLE_BUILD
Other Apps
Created with Hardware Info 3.1.0
76 Guest(s)
Devices in use: Desktop (68), Phone (8)
hans41
rickybk
soniya07
ironmangitar
