2014/08/02
Hi every one,
This is experimental , you will be running P9 kernel on P1Â O_o
Here you can find the patched P9#69_ kernel with the modded resource file, this kernel run best on stock P9 LP or MM ,
if any one want to try it out here it is
I have included here all the important files even the TWRP version 3.0.0.0 recovery included.
Download P1#69_kernel_experimental
Download experimental LP boot.img
Good luck
Note:
this kernel meant to be to the users who has issues with deep sleep and SOD.Â
this kernel it is not perfect,, it is bugy but it is working.. 🙂 some time the external_SD not showing up and ......
The following users say thank you to mussonero1 for this useful post:
Oma7144, mv_b
2014/08/02
2014/08/02
2014/08/02
giaur500 said
Lollipop kernel will cause bootloop for sure
can you explain what you mean?? , i ma lost,, what do u mean by LP kernel ??.
the kernel that you should try with LP is inside the P1#69_kernel_experimentalÂ
2015/11/27
mussonero1 said
giaur500 said
Lollipop kernel will cause bootloop for surecan you explain what you mean?? , i ma lost,, what do u mean by LP kernel ??.
I mean lollipop kernel will cause bootloop on marshmallow.
Do which one is to try in cm13? You linked 2 kernels above, which one is designed for cm13? As I can see, both of them causes bootloop for @mv_b
2015/11/27
mv_b said
Giaur500 there is only one kernel inside the zip for lollipop. Mussonero1 says about the boot.img that are 2 different.tried a lot of combinations with boot and resource but tablet didn't openÂ
Ok. If kernel is for Lollipop, it can'b booted with MM. We need clarify from mussonero
2014/08/02
hi
i did not link 2 kernels, only one P1#69_kernel_experimentalÂ
inside the p1#69#kernel.zip there is a boot.img and kernel , that one is for MM and cm13
but to make it run on my cm13 u need to install mali fix too and cams fix plus you have 3 resources files try any one of them and see the results . i recommend testing on LP or MM not on CM13 , this kernel dose not meant to run on Cm13_P1 made by me.
2014/08/02
giaur500 said
Hi,Can you please pack all above into one, single twrp ready zip, that can be applied on your cm13 build?
if i do, where is the fun in that,, i thought this for experimental so you can know more about the tablet and how it works.
,, just flash a stock LP and replace the kernel ,resource and the boot for first try .
2015/11/27
I know something, but you know much more than I know 🙂Â
126 Guest(s)
Devices in use: Desktop (109), Phone (16), Tablet (1)
JozekPL
Nobrubbr
pall668
Debilai1234
senaslapinas
WINL
