[ RK3288 ROM ] Teclast P90HD 4.4.4 custom root firmware (2014/08/09)
This is a multi-window build for a6k6 and a6k7.
AtiLover
Pisa, Italy
31
2015/02/07 - 00:29
A6K7.jpgImage Enlarger
One Plus One Sandstone Black 64Gb + Teclast P90HD A6K7
32
2015/02/07 - 00:35
You stated that the a6k7 kernel doesn't boot the tab.
AtiLover
Pisa, Italy
33
2015/02/07 - 00:47
I`m using the tab without recovery, I can install omniHD, one old 4.4.2 and a 4.4.4 btw even without CWM
stevemc1979
34
2015/02/07 - 01:01
Got mine mostly fixed. I used the ROM from the crewrktab page. 4.4.2 v1.1 Brightness and rear cam works now. Still no luck with youtube past 720. yourtube "fixes" the default pane but no change to the resolution. No big deal really. Thank you for your time and patience OMA.
79 Guest(s)
Devices in use: Desktop (72), Phone (7)
jacksonrid
usdown
ibob64
kawi
vetBro
