Gents,
KTU84Q has landed on Teclast P90HD
>>> CWM for P90HD
a6k7
kernel york #822 (change both images in folder rockdev/Images before flash)
cRom v2.1
model fix (to be installed via CWM)
a6k6
kernel york #854 (change both images in folder rockdev/Images before flash)
cRom v2.2
– stock recovery 4.4.0
– kernel york #683
– 4 GB internal storage
– multi-windows 2.0
– Dateimanager HD (Root)
– Nova LauncherÂ
Hints:
...use Nova launcher and set animation/scroll to "faster than light" and
...enable Entropy Fixer with value 256
– Oma -
Fine. Did you find bugs or do you have some more feedback?
Youtube works for me. Can you give me an example?
I do not own the game so I cannot test. Sorry.
2014/08/10
Well with youtube the video get messed up also with the players you put in the ROM I have to change to sw instead of hw. The audio have a Hess to it if I play ihart radio or a low quality YouTube video. The games is that the controller are not map like the game has it maped some how the driver skews with the controller mapping if the was a way to turn off it be good.
Currently Online: shauman
89 Guest(s)
Devices in use: Desktop (76), Phone (12), Tablet (2)
rkg2303
sergey-tax
houseofcandy
duviauxi
benevento89
pablovs
