[ RK3288 ROM ] Teclast P90HD 4.4.2 custom root firmware (2014/07/29)
This is only for the old hardware revision A6K6.
guyrandom
121
2015/06/14 - 19:52
Thank you so much, I really appreciate it 🙂
I just sent a donation via paypal, I hope it helps to continue your awesome work.
122
2015/06/14 - 21:08
Thank you very much!
rao
123
2015/06/14 - 21:20
Hi Oma, any chance of lollipop for teclast p90hd? Thanks for the hard work!!
124
2015/06/15 - 20:40
Our AOSP 5.1.1 builds are running on ifive Air and Pipo P1/P9 - http://crewrktablets.arctablet.com/?p=5207&preview=true&preview_id=5207&preview_nonce=7b085aacbb
Currently we need to understand the implementation of the Power Management Unit (Ricoh916). P90HD has similar hardware, so time will come 😉
frmys
125
2016/02/29 - 20:02
I have seen on some youtube videos  other Rk3288 devices test with Antutu Video Tester 2.2 ( actual version is 3.0). They can play all the videos properly also with sound but my Testlast on 1.26 firmare can not play all.
Is there a way to copy and use the other Rk3288 devices codec files or any other trick to improve hardware video playing compability? Also this tablet has audio sync problems on 4K HEVC videos
Rikomagic MK902II RK3288
Also is it posible to use open gl 3.1? According to specs Rk3288 has :  2160 @ 60fps / H.265/H.264/MVC/VP8 encoder OpenGL ES2.0, 3.0 , 3.1 & OpenVG 1.1 & DirectX 11
Is it possible to to cheat 3D mark benchmark program to this that device is running on Android 5.x ? Build props does not work.
Any news for Android 5.x update or Ubuntu or windows intallation?
Best Regard
126
2016/02/29 - 21:18
Development stopped with Android 4.4.4 multi-windows edition. For later Android builds one will need a kernel with selinux support.
Picture is done right now running Antutu Video Tester 3.0 on my build v2.2.
With KK you are also limited to open GL 3.0. There are simply no driver. You are right, 3DMark will give you not an option - picture is from my Pipo P9 running CM13 😉
v2.2_11.pngImage Enlargerv2.2_12.jpgImage Enlargerv1.2.4_52.jpgImage Enlarger
75 Guest(s)
Devices in use: Desktop (69), Phone (6)
werasler
5256makc
e-victor
vienzo
superdavex
giorgioo@freemail.hu
