[ RK3288 ROM ] Teclast P90HD 4.4.2 custom root firmware (2014/07/29)
This is only for the old hardware revision A6K6.
61
2014/10/03 - 16:52
I guess this was out-of-the box the case and all your other devices have no such problems?
djvautrien
62
2014/10/03 - 17:51
Yes out of box, no my ipad or phone havent this problem
63
2014/10/03 - 17:53
Ok, then the issue is hardware driven. Best is to make use of your warranty.
rene13cross
64
2014/10/06 - 13:15
Any feedback on the V1.26 changelog? Is there an improvement in screen contrast?
There are changes on the camera HAL and the GLES libs.
Hi again,
So I finally got around to flashing v1.5 of this rom and I can confirm that the screen contrast is much improved! Still not as good as a true IPS panel (regarding white balance -- appears yellow in comparison to the IPS panel on my iOcean X7), but comes close now regarding the contrast.
Haven't come across any issues with your rom yet -- fast and responsive so far. The camera still sucks but that's not something I care about in a tablet (as oppose to in a phone).
Again, thanks Oma for the hard work you've done.
The following users say thank you to rene13cross for this useful post:
hnito82
Forum Posts: 11
65
2014/10/07 - 17:10
Gents,
This is the first custom build for Teclast P90HD ;-)
P90HD by Oma build v1.0  (based on stock v1.18)
P90HD by Oma build v1.1  (based on stock v1.19)
P90HD by Oma build v1.2  (Play Store fixes and corrections on gapps provider)
P90HD by Oma build v1.3  (based on stock v1.23)
P90HD by Oma build v1.3.1  (full gapps incl. google now launcher)
P90HD by Oma build v1.4  (based on stock v1.24, incl. full gapps)
P90HD by Oma build v1.5  (based on stock v1.26, incl. full gapps)
– stock recovery 4.4.0
– kernel york #618 [v1.0], kernel york #683 [v1.1], kernel york #817 [v1.3, v1.4], kernel york #854 [v1.5]
– 4 GB internal storage [v1.1]
– gameloft compatible
– usb-hub enabled
– init.d support
– Dateimanager HD (Root)
– Nova Launcher, Google Now Launcher
Hints:
– start with Nova Launcher to enable proper contacts services!
use Nova launcher and set animation/scroll to “faster than light” and
enable Entropy Fixer with value 256
– to prettify the build use
Xposed Framework > Starter Pack
– Oma -
v1.0_04.jpgImage Enlargerv1.0_03.pngImage Enlargerv1.0_02.jpgImage Enlargerv1.0_01.jpgImage Enlargerv1.0_05.pngImage Enlarger
v1.0_06a.pngImage Enlarger084.jpgImage Enlarger
oma hello, I have a teclast g17h 3g is very good except that I can not use the memory to sd move app or file. there is a method to set it as primary?
66
2014/10/07 - 20:43
I do not have experience with a Mediatek architecture. Sorry.
rivanov
67
2014/10/16 - 20:02
Hello everybody. Does P90HD have the same display model as in Kindle fire hdx 8.9? Or they are just similar, but not the same?
rene13cross
68
2014/10/16 - 20:11
Not sure if its the same model since Amazon dubs their display "HDX" whereas Teclast calls the display in the P90HD "Super Retina".
Unfortunately I've never had a Kindle Fire HDX 8.9" hands-on so I can't comment on whether the displays look the same but I can tell you that (coming from using an IPS display on my iOcean X7 regularly) it is not nearly as good as IPS or PLS in color correction but is still better than pretty much any TN panel.
Maybe someone here who has more knowledge on these matters can tell you for definite.
rene13cross
69
2014/10/16 - 20:21
Display is from JDI. Should be the one marked in the attachment.
So is it the same display??
rivanov
70
2014/10/17 - 21:26
Is the source code available for the kernel and the firmware?
71
2014/10/17 - 21:36
TornadoZ said
Hello Oma,
This is Vincent from Teclast company.
We would like to know your comments of our tablet products.
It's our honor that you enjoy to use P90HD.
We noticed that Rockchip is now more open for sharing sources and best practice.
If you'd like you can contact me via PM for further discussions.
Never heard anything from this guy. If someone else can provide code ...
techtune91
72
2014/10/25 - 10:44
Plz..For me HDMI is not working......And Your Rom is awsome !!!!!
Thank you Vermy much oma
73
2014/10/25 - 11:12
Works fine with my 55" machine. What is the problem exactly?
v1.5_05.jpgImage Enlarger
74
2014/11/14 - 14:22
There is a new hardware revision in the field, called A6K7.
Kernel is york #822, preempt 21. Oct 2014.
For the moment I don't know what the difference is. At least the cam is different.
So pls be careful!
A6K7.pngImage Enlarger
thomas199717
75
2014/11/16 - 10:24
Hi oma
thanks for your custom firmware
Now android 5.0 lollipop is released are you planning to make android 5.0 available on the teclast p90hd?
Many thanks
Thomas
64 Guest(s)
Devices in use: Desktop (54), Phone (10)
