Gents,
This is the first custom build for Teclast P90HD
P90HD by Oma build v1.0Â (based on stock v1.18)
P90HD by Oma build v1.1Â (based on stock v1.19)
P90HD by Oma build v1.2Â (Play Store fixes and corrections on gapps provider)
P90HD by Oma build v1.3Â (based on stock v1.23)
P90HD by Oma build v1.3.1Â (full gapps incl. google now launcher)
P90HD by Oma build v1.4Â (based on stock v1.24, incl. full gapps)
P90HD by Oma build v1.5Â (based on stock v1.26, incl. full gapps)
– stock recovery 4.4.0
– kernel york #618 [v1.0], kernel york #683 [v1.1], kernel york #817 [v1.3, v1.4], kernel york #854 [v1.5]
– 4 GB internal storage [v1.1]
– gameloft compatible
– usb-hub enabled
– init.d support
– Dateimanager HD (Root)
– Nova Launcher, Google Now LauncherÂ
Hints:
– start with Nova Launcher to enable proper contacts services!
– to enable multi-user use the Xposed module Multi Users Â
– Oma -
Johnnyb119, admin, Merzthik, bobb, TornadoZ, techtune91Per aspera ad astra, we rock the Tablets !
2013/08/27
Hi men.
This rom is based on the new official firmware from Teclast (v1.18)?
In the initial official roms the tablet has bugs and something like that. With the new version (1.18) they fixed the most of their bugs.
My question is, your version has this bugs??.
Thanks man and ill try your rom asap!
EDIT: They released yesterday a new version (1.19)
Yeah, based on stock v1.18 (kernel #618). You will find the changelog in the download pack.
My tab came with stock v1.13 (kernel #525).
V1.18 version update:
1, added support for exFAT format SD card;
2, the solution after the application is installed, you can not move to the SD card;
3, solving the first 10 seconds after power is not immediately press the Power button to lock the screen;
4, updated camera module, optimized camera shooting;
5, repair browser tab switching, video did not stop and continued to play bug;
6, modify the "Settings - Storage" characters do not display correctly in SD issues;
7, the probability of multiple video playback fix stuck playing small window Caton, green screen, abnormal;
8, does not lead to timely repair memory recovery caused by low memory systems Caton abnormal;
9, optimized multi-tasking;-------------------------------------------------- ---------------------------------------
V1.14 version to improve the content:
1, fix the machine back to factory settings and check the "Format", the disk label is modified bug;
2, the machine even OTG-U disk will be prompted to "Preparing SD Card" was revised to correct information "Preparing USB storage device" prompt;
3, shielding the system default video player scans dat file format;
4, increasing the camera to take pictures voice;
5, set the 3G-dongle update information;
6, increasing the set - projection screen, support WiFi-display;
7, optimize system memory allocation strategy to enhance the system performance;-------------------------------------------------- ---------------------------------------
P90HD (A6K6): The first version of the firmware release.
Ok, looks good. New kernel york #683: http://crewrktablets.arctablet.com/?wpfb_dl=1971
Version: V1.19_20140723 (android 4.4.2) Update:
1, increase online upgrade OTA upgrade package deleted;
2, shield set - start by option - Drawing - Analog secondary display device;
3, modify QQHD / QQHD-MINI version of the video call direction normal;
4, updated mali driver version, repair low probability anomalies;
5, repair USB drive null pointer problem;
6, the effect of improving the optimization Camera, specifically:
   7, increasing the exposure compensation, white balance;
   8, increasing the AF fine focus, enhance photos clarity;
  9, optimizing shooting, repair Continuous shutter silent problem;
  10, the low probability of entering the camera click repair videos, tips to stop running;
  11, repair probabilistic cause micro-channel sweep the camera preview black;
  12, no zoom effect problem fixes 5M zoom camera;
  13, repair preview video frame bounce problems that may arise;
Will do a new custom build when I got some more feedback.
MerzthikPer aspera ad astra, we rock the Tablets !
Update post #1 with build v1.1.
Update post#1 with build v1.2.
bobbPer aspera ad astra, we rock the Tablets !
2014/08/04
great job man, while i went to recovery mode, it showed the android robo with red triangle, but my computer didn't recognize usb device. It works fine in normal mode, but not in recovery mode. I am still on v 1.13, it hangs every now and then. please help. It don't even recognize my sd card in recovery, says no such device found.
You mean you'd like to start the tab into flash modus?
When you see the Android robo the tab booted into stock recovery. This indicates that the flash driver are not installed. Use the included Driver Assistant to install the usb flash driver.
Merzthik said
Hi guys.I tried the 2 latest official roms (1.18 y 1.19) and Oma's rom 1.1 and I only haven't lag with the UI (Google now launcher) with the 1.18 official rom (I didnt try your 1.0 version yet).
I think with 1.18 kernel the rom is more fluid than 1.19.
Well, UI feeling is not better then on my rk3188 machine ...
For best UI feeling I'd recommend:
- disable all animation scales in developer options,
- use Nova launcher and set animation/scroll to "faster than light" and
- enable Entropy Fixer with value 256
To test kernel #618 in the v1.2 build just flash it (tick parameter and kernel).
2013/08/27
Well. With 1.18 official version i have no lag in UI. I had a Pipo M9 Pro and that was a lagged UI xD.
Compared with my Nexus 5 isnt the same but the UI is good in this tablet
49 Guest(s)
Devices in use: Desktop (38), Phone (11)
