Gents,
This is my first build for Pipo P7
– stock recovery 4.4.0
– kernel #369 preempt 08.10.2014
– 4 GB internal storage
– Multi-User
– Dateimanager HD (Root)
– Nova Launcher
Hints:
– Oma -
TuscaniV6Per aspera ad astra, we rock the Tablets !
2015/01/26
Thank you very much for this rom OMA, everything runs nicely on this one.
There is only a single flaw on this rom that gets really annoying, and that's the internal storage being used as the default write disk without the ability to switch to external SD for application data.
Also i'm not sure if this is because of the kernel or the rom itself, but this device is unable to mount a 64GB Samsung SD card in android, that's strange too because in recovery (TWRP) the card is mounted properly and you can transfer files without problem. So for now i'm stuck with a 32GB one.
Do you think you can add these features with a small new update for this rom?.
Thank you again for your hard work on all the devices.
EDIT: Oops wrong thread, i was posting this for newer rom with kernel #700.
Mods delete this post anytime please. Sorry for the hassle.
Currently Online: kalkpits
69 Guest(s)
Devices in use: Desktop (63), Phone (7)
kalkpits
m12k
StatusQ
helloyuen
melcis
nelcis
