Gents,
This is the first custom build for R-Box
– stock recovery 4.4.0
– kernel ant #55
– Reboot Menue
– Dateimanager HD (Root)
– Nova LauncherÂ
– Oma -
Could be that the usb flash-driver is not installed properly or you use an older one, which will not work here.
The pack in post #1 contains a Driver Assistant. Copy the pack into c:. Run the Assisteant and de-install driver first. Goto Windows device manager and if you find other RK driver de-install them manually. Now install driver. Start the box into flash-mode and the flash driver should now be installed.
2014/08/10
I did that with the usb driver works great now when i install everything i get to the main home screen , busy box is not installed and also the rooot breaks compleatly when you load it up. figured out how to unbreak the device it is very easy. it takes a few steps but ill but it on an walk through once evrything is working. so if you have another way to root the device please let me know. thanks and once i get the help ill give you a good tip...
That works all fine for me. Do not touch the build. Install again incl. LowerFormat.
2014/08/10
how can i change the cpu overclocking to 1.8ghz or 2.0 ghz, stock is 1.6ghz. is there a way to get that working. i am building a new rom but need help with that now. i got the whole box working now. it is fat but still can improve a bit. i have added a heat bsink and fan to the device, so it is well cooled
Fine.
Let us see a few pictures of your box/setup and screenshots of settings/About the tab and Antutu.
2014/08/10
ok her is the link https://plus.google.com/photos/110768010524477036296/albums/6046522475913292177
Cool, what Box is it?
For overclocking we need the kernel sources.
2014/08/10
this what i have at my house which i been playing over 4 weeks now but now want to program.
so lets start what do you need
https://drive.google.com/folderview?id=0B1w20Z1fgmuCT0ZqRktuU212ZG8&usp=sharing this is all the dump images for the unit.  does not have user.img or userdata.img
Ok, the firmware on your tab is pretty much the same than in post #1.
2014/08/10
so what should i do? what can i modify to get to the CPU frequency varies from 1.6 GHz to 2.0 Ghz.
As I said before, we need the kernel sources to compile a overclock kernel. Ask the guys or the company. They have to publish them: https://gnu.org/licenses/gpl-3.0.en.html
2014/08/10
so is there a way to get it with out getting it from the company. Â Could you make a generic one for your r-box so i can try out an fix it over time. the company is chines and their they emailed me a broken link and corrupted download
could you try these.
https://kernel.googlesource.com/pub/scm/linux/kernel/git/mmind/linux-rockchip/
Ask them again. We need Rochchip sources for the 3.10.0 kernel.
88 Guest(s)
Devices in use: Desktop (75), Phone (13)
PATRYK-VP
victorialp23
alertscam
aolmail7448
Arc123456789
forty42
