What kind of problem?
When it does not appear kernel won't detect it, which means it is defect or connection to it is loose.
What was stock/kernel?
You have to use kernel #158.
2015/04/20
Hi, Oma,
I've recently purchased Pipo P9 3G 32gb, and it comes with stock firmware 214 version,
and thinking of flashing your 1.2 rom on device
just wondering about internal memory, in stock it has 2 Gb of storage, + 25gb built in sd,
does your rom adjust it? Would like to have at least 6 Gb of inner storage, instead of 2.
Or how can I increase that partition?
thanks a lot for your unput !
p.s. Can i successfuly flash it if I have Windows 8 64bit ?
2015/04/20
Hi, few hours ago i flashed my pipo p9 with oma 1.2 firmware. (With lower format)
It seems to work ok, but:
1. Back camera is not working, software that shows device info find only front camera.
2. Problem is found when turn automatic display brightness on: touch becomes almost not responsive, freezez the system, when auto-brightness off, everything works well again.
Please fix these problems.
2015/03/31
valteam said
Hi, few hours ago i flashed my pipo p9 with oma 1.2 firmware. (With lower format)It seems to work ok, but:
1. Back camera working fine on my tablet (sometime the pictures are out of focus)
2. Again its working fine with automatic display on
try to reinstall the firmware, maybe it had a bad flash? if you still having problems try RileyROM 1.9 firmware.
70 Guest(s)
Devices in use: Desktop (60), Phone (10)
sidor
houssmen
qarolus
dav512
tgergely2012
avv2011
