[ ROM ] Pipo P9 wifi/3G 4.4.2 custom root firmware (2014/12/23)
2014/12/26 - 15:53
Gents,
This is my first build for Pipo P9 ;-)
Build is based on stock, dated 10. Dec 2014 (wifi) and 11. Dec 2014 (3G)
and the common kernel #213 preempt 10. Dec 2014.
P9 wifi by Oma build v1.0
P9 3G by Oma build v1.0
Update 29.12.2014:
- corrections of some wakelock issues of the stock firmware/kernel
- some minor corrections
- update to TWRP 2.8.3.0
P9 wifi by Oma build v1.1
P9 3G by Oma build v1.1
Update 07.01.2015:
- finally all working (wakelocks, battery drain, cam)
– kernel #158
– CWM 6.0.5.1 added
P9 wifi by Oma build v1.2
P9 3G by Oma build v1.2
– stock recovery 4.4.0
– CrewRKTablets recovery CWM 6.0.5.1 [v1.0], [v1.2]
– CrewRKTablets recovery TWRP 2.8.0.0 [v1.0], TWRP 2.8.3.0 [v1.1, v1.2]
kernel #213 [v1.0], kernel #158 [v1.1, v1.2]
– 4 GB internal storage
– init.d support
– multi-user
– RebootMenue, sEFix, FX Sound
– Dateimanager HD (Root)
– Nova Launcher
Hints:
use Nova launcher and set animation/scroll to “faster than light” and
enable Entropy Fixer with value 256
– to prettify the build use
Xposed Framework > Starter Pack
– Oma -
084.jpgImage Enlarger
 Oma-RK32-P9-3G-build-v1.0-23.12.2014.pngImage Enlarger
 v1.0_04.jpgImage Enlarger
 v1.0_02.jpgImage Enlarger
 v1.0_05-1.pngImage Enlarger
 v1.0_codecs.pngImage Enlarger
 v1.0_08.jpgImage Enlarger
 v1.0_09.pngImage Enlarger
 CWM_CrewRKTablets_v1.0.jpgImage Enlarger
 TWRP_CrewRKTablets_v1.0_2.jpgImage Enlargerv1.0_kitkat-1.pngImage Enlarger
aundp
2014/12/29 - 07:48
Nice!
Gonna try this one.
I'm on RileyROM now. Have many issues with WiFi wake up and battery draining.
Hope this one (Oma) is good
2014/12/30 - 21:06
Update post #1 with build v1.1.
– corrections of some wakelock issues of the stock firmware/kernel
– some minor corrections
– update to TWRP 2.8.3.0
Oma-RK32-P9-3G-build-v1.1-29.12.2014.pngImage Enlarger
 v1.1_wakelock_01.pngImage Enlarger
 v1.1_wakelock_02-1.pngImage Enlarger
 v1.1_wakelock_03.pngImage Enlarger
 CrewRKTablets_TWRP_v2.0_04-2.jpgImage Enlarger
2014/12/31 - 14:12
After some further testing battery drain shows now a (for me) satisfying level ;-)
Battery-Test_2-2.pngImage Enlarger
2015/01/05 - 22:04
For some reason the cam is not working. Fix added to post #1.
v1.1_cam.jpgImage Enlarger
f0k4l
2015/01/06 - 02:08
For some reason TWRP is not reading anything on my device when in Recovery. It doesn't have an "Internal SD" option, only External and USB Storage, but even as External selected by default, it doesn't read anything on my card either. I'm trying to flash my apps so I don't have to download them again, any ideas?
f0k4l
2015/01/06 - 03:01
I tried flashing CWM to see if that would work, and same thing.. maybe I had a bad ROM install somehow. Well I was going to try to reinstall, and then my HDD stopped working after a reset.. gotta be kidding me. Things not even two years old.. ugh. Luckily it's just a backup HDD and not my main SSD, but now I gotta mess with the warranty on this thing.
2015/01/06 - 05:24
Doesn't make sense to install from internal sdcard. However, when you like to do so mount it first in the Mount menue.
f0k4l
2015/01/06 - 17:01
On TWRP 2.8.3.0 I get an error log when booting into recovery which says cannot mount storage, hence why nothing shows up in any menu. I flashed it again and even did a clean wipe reinstall of the rom to no avail.
I flashed twrp 2.8.0.0 and that version works fine as it should with no errors. Is anyone else having 2.8.3.0 issues?
2015/01/06 - 17:14
Lets me test that. The wifi or the 3G package?
f0k4l
2015/01/06 - 17:16
Wifi
2015/01/06 - 17:23
Just did a clean install ... works fine at my end. Try again incl. Lower Format.
f0k4l
2015/01/07 - 01:56
Yeah.. No dice. 2.8.3.0 just doesn't like my p9, oh well I'll just have to use 2.8.0.0 no biggie.
Maybe I got one of the oddball pipo's. Sometimes my screen has a "Ghost Touch" that will esc+ volume  down once.. So if I'm surfing  the web it will go to previous page + volume  down, or if I'm watching a movie it will close + volume  down etc.. It doesn't happen very often, and is completely random, no pattern what so ever why it happens. I haven't seen anyone else report this issue, so I figured it must just be mine.
2015/01/08 - 09:09
There is a new stock around dated 18. Dec 2014 with kernel #214 preempt 17. Dec 2014.
Still no progress. Wifi comes not back after deep sleep when option "keep wifi on during sleep" is set to "Never". Battery drain is too high.
wifi_comes_NOT_back_214_3G.pngImage Enlarger
 wifi_comes_NOT_back_214_wifi.pngImage Enlarger
2015/01/08 - 09:47
Update post #1 with build v1.2:
– kernel #158
– CWM 6.0.5.1 added
Oma-RK32-P9-3G-build-v1.2-07.01.2015.pngImage Enlarger
 v1.2_cam_2.jpgImage Enlarger
 v1.1_wifi_comes_back.pngImage Enlarger
 v1.1_wifi_comes_back_deep_sleep.pngImage Enlarger
 TWRP_CrewRKTablets_v2.1_5.jpgImage Enlarger
Currently Online: VMILCINOV
69 Guest(s)
Devices in use: Desktop (66), Phone (4)
VMILCINOV
