This is a kernel issue. Same effect with all kernel?
2014/10/28
To Oma
I used the software suitable for the battery (battery monitor widget pro). How can I provide you with information related to the battery?
I think I have a battery problem because I went from 70% to 1% very quickly.
Also I read on another forum that a new version improves the battery.
I put the link http://pan.baidu.com/s/1kTzHJkr
Source: http://www.freaktab.com/showthread.php?17734-Pipo-P8-RileyROM-1-2-Android-4-4-4/page2
Best regards
2013/06/01
Hi Oma,
I'm happily using your ROM and it works perfectly fine for me (besides battery drain) - according to statements in other forums like Freaktab there is already a new version of the official PIPO P8 ROM available (Pipo firmware dated 11/6/14 #177).
Any chance to get a new version of your ROM based on that version ?
Thanks a million !
Jo
New kernel #177 preempt 06.11.2014: http://crewrktablets.arctablet.com/?wpfb_dl=2224
2013/06/01
EDIT:
post below is obsolet in the meantime as I went ahead in a try-and error approach and I have just installed the new kernel - perfect ! My P8 works even better - the smoothness increased to what I can tell so far with kernel #177. Battery drain I can't tell that much s it is still charging.
Perfect - thanks, Oma!Â
Regarding installation of the kernel: do I need to
- install just the new kernel with RKAndroidTool or
- install the new kernel with the loader with RKAndroidTool or
- install the whole ROM including the new kernel?Â
Thanks  for your support!Â
Jo
2014/11/14
I have stock ROM but I noticed horizontal scroll is laggy. It slows down every centimeter when I scroll horizontally. I tested it with drawing app and when I draw parallel lines it draws zig-zag lines and it looks like the screenshot. It seems like touch has vertical bands with different response. Anyone has the same problem?
2013/06/01
In the meantime I have figured out the root cause of the battery drain: it is the UltraStick modem with causes the higher consumption.Â
It was already factory installed an as soon as I have taken out the stick, the P8 was able to enter deep sleep mode.Â
Jo
The following users say thank you to avant for this useful post:
Interesting finding. Thanks for feedback.
2013/06/01
Hooray - A new version of the ROM has been released as follows :
http://pan.baidu.com/s/1eQeTVEi
Cheers
JoÂ
New kernel #194 preempt 01.12.2014: http://crewrktablets.arctablet.com/?wpfb_dl=2287
2013/06/01
Thanks Oma !
I do have the following issues with the ROM as follows (kernel #177 *and* #194):
- the app Magine freezes after some minutes (not seen on other tablets/smartphones in the same wlan)
- last but not least - the P8 does not wake up from deep sleep and needs reboot
Thanks again !
Jo
EDIT: I am still wondering, if 5GHz WLAN is implemented at all as announced. I don't see any 5GHz WLAN compared to my other 5GHz WLAN devices ...
Deep sleep issues are always kernel/hardware related. Wifi depends on the wifi chip. Let me have a dmesg log.
77 Guest(s)
Devices in use: Desktop (69), Phone (8)
sidor
houssmen
qarolus
dav512
tgergely2012
avv2011
