Gents,
This is my first build for Pipo P7
Build is based on stock, dated 23. Dec 2014 (wifi) and kernel #674 preempt 23. Dec 2014.
Update 02.01.2015:
- fix broken Contacts
- fix Chrome red frame issue
- some minor corrections
- TWRP 2.8.3.0 corrected to right resolution 1280x800
P7 wifi by Oma build v1.2 based on stock, dated 30. Dec 2014 (wifi) and kernel #700 preempt 30. Dec 2014. Fixed same issues.
Update 17.03.2015: kernel #825 (change kernel/resource in folder rockdev/images before flash)
– stock recovery 4.4.0
– CrewRKTablets recovery CWM 6.0.5.1
– CrewRKTablets recovery TWRP 2.8.3.0
– kernel #674, kernel #700 [v1.2]
– 4 GB internal storage
– init.d support
– multi-user
– RebootMenue, sEFix, FX Sound
– Dateimanager HD (Root)
– Nova Launcher
Hints:
Special thanks to netlars !
– Oma -
seiboPer aspera ad astra, we rock the Tablets !
Minor fix for broken Contacts and Chrome red frame issue added to post #1.
2015/01/09
Any chance of multi-window support for the P7? With multi-window support, it would make this tablet the best, for price/performance.
The RK3288 is one of the fastest *stable* ARM socs out there, at the moment(and has better compatibility/performance than the Intel Atom for most things).
I can do that when I know what's going on on the tab. So, I would be happy to see some feedback of how the builds in post #1 performs.
So, nobody feedback here?
Pls test: http://crewrktablets.arctablet.com/?wpfb_dl=2367
Following a recent server issue (you can read about it here) here is a list of the the missing posts in this topic from the past days. Please excuse the raw formatting, this series of replies is just copied here for your convenience to keep the topic history. Replies are listed sequentially, oldest first in the list.
Post:
Interesting. Install this via TWRP/CWM:
Hi, I have detected a minor bug: It's not possible to change the launcher.
I installed google now launcher and there is no way to open it because is impossible to quit nova as the default launcher. Thank you!
Post:
Goto settings/Home and change the launcher.
Post:
I searched that but Home is not included in the settings
Post:
You are right it Menue item will not pop-up. Install this and check:
Post:
You are right the Menue item will not pop-up. Install this and check:
Now any launcher can be used properly. Thank you!!
I will continue testing
Update post #1 with kernel #825 preempt 11.03.2015.
Pls describe the issue a bit more.
2015/03/17
My problem is when I touch the scream,
the tablet takes it as many individual single touch and over react,
which in the end mess up the whole scream and system.
The tablet become crazy and hop from one app to another nonstop.
This happens to me quite often.
I checked the pipo user bbs,
it seems that I am not the only one suffering this,
but also other people.
BTW: This is not because of ROM.
I use different ROMs, because I want to get rid of this problem
The probelm is still there though...
58 Guest(s)
Devices in use: Desktop (49), Phone (9)
