[ ROM ] Pipo P4 4.4.4 custom root firmware (2014/08/09)
Multi-Window build will also work on other rk32boards: P1, P8, P9, mini4
joris21800
46
2014/11/09 - 07:54
hello, i have same problem as fastmediafree, camera flash always on, solution ?
otherwise it's really good work
fastmediafree
48
2014/11/17 - 08:53
Can you pls check this: http://crewrktablets.arctablet.com/?wpfb_dl=2181
How to install ?
Thanks Received: 3171
49
2014/11/17 - 09:20
fastmediafree said
How to install ?
This package contains a the necessary files to get adb working on a computer and a batch file that takes care of copying files on your tablet.
OMA should confirm, but I think it's quite simple: you need a Windows based computer and make sure ADB is running on your tablet. Unpack the archive and run the RUN Oma Patch.bat file. After execution it should pause at the end, please review that it shows no errors.
sandmen
50
2014/12/16 - 11:22
I have currently Installed the rom on a P9 with GSM modul.
Hmm, no dialer or phone function available. Did I need something more?
I used the
http://crewrktablets.arctablet.com/?wpfb_dl=2151
kernel #192 from first post.
and
http://crewrktablets.arctablet.com/?wpfb_dl=2092
P4 build from first post
I have changed the kernel & resource files in rockdev folder.
Peter
51
2014/12/16 - 17:30
Both are builds for wifi only. Use the Pipo P1 3G build.
sandmen
52
2014/12/17 - 03:35
Flashed :-)
but, it hangs on the systemmenuui. Think the statusbar :-(
Any hints?
 And where I need to edit the dpi=240
or just add this line to build.prop ?
kiki78
53
2015/01/07 - 17:49
Dear Oma,
First, please accept my compliment for your work.
I use different tablet for special application.
I customize firmware, so change boot logo and animation and remove unnecessary apps and add mine.
I try to use Pipo P9, and all customization work, but I can't find how to change boot logo (before boot animation).
I see that you never change it in your rom, but have you some information to help me ?
Best Regards,
54
2015/01/07 - 19:29
Which tab do you have?
kiki78
55
2015/01/07 - 19:38
Thank you Oma
This is Pipo P9.
Kiki78
56
2015/01/07 - 20:06
So, interessting why you have choosen the P4 thread to ask questions ;-)
There is no boot logo ... what you see first is the kernel logo.
kiki78
57
2015/01/07 - 23:07
When I go to P9 page I'm redirect to P4...
So, I understand that first image is not part of boot, but part of kernel.
I try to explore kernel.img with hexa editor but without any information I'm confused. Have you some idea ?
Kiki78
fldc
58
2015/01/12 - 15:16
Kiki78
It's in resource.img, use resource_tool to modify this, you can find this tool in one of the rk3288 sdk:s available.
kiki78
59
2015/01/12 - 17:08
Thank you fldc, I will try this and go back with result.
Kiki78
fldc
60
2015/01/12 - 17:38
Kiki78
logo.bmp should use bmp3 (Windows 3.x format), 256 colors, 892 x 324
Unpacking resource.img is pretty straightforward, to repack use something like this,
cd out
find . -type f|xargs resource_tool --image=../resource.img
71 Guest(s)
Devices in use: Desktop (61), Phone (10)
swan12
heftpflaster
