[ ROM ] Pipo P4 4.4.4 custom root firmware (2014/08/09)
Multi-Window build will also work on other rk32boards: P1, P8, P9, mini4
rene90
31
2014/09/10 - 08:54
Video works fine for me. What is the issue with facebook?
v1.4_04.jpgImage Enlarger
Hi OMA
New firmware from China, of 9-9 and they told me the facebook issue is fixed, and also the (still) short standby time.
http://pan.baidu.com/s/1o6nzg74
With thanks to -soukouzen-
rene90
32
2014/09/10 - 23:02
The baidu link is offline now, but i already downloaded it and upload it somewhere else:
http://we.tl/eas7B3yut8
Flow63
33
2014/09/18 - 16:57
@ Oma7144
Thanks for this great rom :)
I'm running it on my PIPO P9.
I just noticed there's a new build out (15-09-2014) here:
PiPO P9_Software_Chinese version_NO 3G_20140915
Source:
http://www.pipo.cn/En/index.php?m=Product&a=show4&type=2&id=342
Do you happen to know if PIPO uses OTA?
The following users say thank you to Flow63 for this useful post:
34
2014/09/18 - 17:39
Welcome Flow63!
First of all thank you for the feedback! There is unfortunately not much.
I've never seen OTA from Pipo.
Kernel #138 from that 20140911 update is in the archive: http://crewrktablets.arctablet.com/?wpfb_dl=2106
You can flash it separately, just tick parameter, kernel and resource.
Flow63
Flow63
35
2014/09/18 - 18:11
Thanks again.
Btw can i go back to stock firmware with RKAndroidTool and just tick "system.img"?
36
2014/09/18 - 18:16
Yes. Parameter and system. The difference between 4.4.4 and 4.4.2 should not generate problems.
Flow63
Flow63
37
2014/09/18 - 19:45
Just tried to go back to stock, but it failed, it doesn't go past the boot screen and when i reset the device i get the dead android on my screen...
Tried 2 firmware images:
1. update_PiPO P9_NO 3G_20140826.img
2. update_PiPO_p9_no_3G_20140911_v1.1.img (i think this is a Chinese version).
I flashed your image back and it boots ok again.
Do you know howto access recovery on this device? (it has no hardware volume buttons).
Btw. it's lightning fast :)
Edit: seems that i don't have sound anymore, any ideas?
Edit2: with the official program i went back to stock and sound was working again.
38
2014/09/19 - 07:47
To flash the update.img use the RKBatchtool. As this is the factory tool it will completly reset anything, incl. the loader.
39
2014/09/20 - 14:41
Pipo deliver the P8 without Multi-Window support.
Update post #1 with Pipo P8 kernel #153 preempt 17. Sep 2014.
Berni51
40
2014/09/23 - 23:00
Hi Oma,
how to Flash Pipo p9? There is no power-up. Do you have any instructions for it?
Flow63
41
2014/09/23 - 23:41
The instructions are on the official website here for the official rom and in the package if you want to install/flash the OMA rom.
In short: press power and escape until the device powers down, then quickly press power and escape again, the screen goes black and then you can see, in the official upgrade tool, a green square. In the oma flash tool "One Loader Device".
42
2014/09/25 - 07:51
Update post #1 with Pipo P8 kernel #160 preempt 20. Sep 2014.
The tab has only the Power button. To start into flash modus try the hold Power and press Reset.
fastmediafree
44
2014/11/06 - 14:28
I have a problem with my P1,  flashing the firmware (I tried with build 1.1,1.4 and 1.5 and kernel #462 and kernel #489  ) the camera flash is always on, how can I fix this?
Berni51
45
2014/11/07 - 10:55
Hi, was anyone successful flashing one of Omas roms on pipo P9? I have tried it with RKBatchTool failing because of missing the update.img. I also tried it with AndroidTool getting the message that I have the wrong device. The Image files I have coped to the Image Folder. It would be nice to get a howto.
Berni51
72 Guest(s)
Devices in use: Desktop (62), Phone (10)
swan12
heftpflaster
