[ ROM ] Pipo P4 4.4.4 custom root firmware (2014/08/09)
Multi-Window build will also work on other rk32boards: P1, P8, P9, mini4
2014/08/20 - 18:58
Update post #1 with build v1.3.
v1.3_01.pngImage Enlarger
locutus2000
Forum Posts: 22
2014/08/22 - 10:18
V1.3 also has 1.2 filename when downloading?
edit: your link has troubles, both files are linked:
http://crewrktablets.arctablet.com/?wpfb_dl=2027
should be correct link
2014/08/22 - 12:56
Thank you! Links in post #1 corrected.
2014/08/23 - 18:00
TWRP has landed on rk32board ;-)
All credits to AbduL_PT. Great work!
May I ask somebody to give feedback if this is working? Thank you in anticipation!
- Oma
0000000
2014/08/24 - 14:28
Unable to enter the system and you can not mount the internal storage
http://upload.pmp4.net/g/20140824202854k1j66.jpgImage Enlarger
2014/08/24 - 15:00
This is a R-Box?
rene90
2014/08/28 - 18:29
I also flashed 1.3 from you, but there's still a battery drain. In 1 hour with wifi off it's 4% down (screen off). At my battery statistics i see "mobile signal" what is using battery, so maybe that's the reason it is still draining? Because there is no 3G built in?
oryzae
2014/08/29 - 09:32
Hello. I have a problem with power.
when sleep mode get longer, power goes out. It varies from 10 minutes to a couple of hours. not power drain, just turning off.
Do you have an idea of this phenomenon?
soukouzen
2014/08/29 - 12:27
Oma I'm sorry, because this is a foreign website, I loaded the site very slow, so it is not often on this site, only when there is a new firmware I will visit this site. As far as I know the PIPO P4 problem on the battery, China have this problem a lot of user feedback. You only have to wait for the official later firmware update.
        -soukouzen-
soukouzen
2014/09/02 - 14:56
Oma,
  I'm sorry, I opened the forum to spend approximately 10 minutes. Really not easy.I can only use the mailbox let us exchange. My email :shr923@126.com
Also to provide you with this update P4 firmware.
WIFI:http://pan.baidu.com/s/1ntiHqmX
3G: http://pan.baidu.com/s/1ntmLaZJ
        -soukouzen-
2014/09/08 - 09:13
Update post #1 with build v1.4.
Pipo implement some measures to prevent the build from rooting. The question is why?
v1.4_03.jpgImage Enlarger
rene90
2014/09/08 - 09:26
Hi Oma,
Thanks for the update, can you inform me if facebook is working correctly and video's on the timeline are playing correctly. On the Riley 1.6 ROM you get green bars in the video (sound is fine).
I hope it works because then i will flash it ;)
2014/09/08 - 10:20
Video works fine for me. What is the issue with facebook?
v1.4_04.jpgImage Enlarger
rene90
2014/09/08 - 10:24
Normal video's also work fine for me, it's the problem with video's on the timeline in the facebook app, when you play them i get this, the sound works fine but the image is like this:
http://i.imgur.com/ZvMaU4T.jpgImage Enlarger
The following users say thank you to rene90 for this useful post:
Djuganight
96 Guest(s)
Devices in use: Desktop (80), Phone (16)
heftpflaster
rk.13
