[ ROM ] Pipo P4 4.4.4 custom root firmware (2014/08/09)
Multi-Window build will also work on other rk32boards: P1, P8, P9, mini4
2014/08/09 - 20:41
Gents,
Android 4.4.4 has landed on Pipo P4 ;-)
 P4 by Oma build v1.5
 P4 by Oma build v1.4
 P4 by Oma build v1.3
 P4 by Oma build v1.2
 P4 by Oma build v1.1
– stock recovery 4.4.0
kernel #521 [v1.1], kernel #568 [v1.2], kernel #587 [v1.3]kernel #613 [v1.4, v1.5]
– 4 GB internal storage
– Dateimanager HD (Root)
– Nova Launcher, Stock Launcher [v1.3, v1.4]
Hints:
...use Nova launcher and set animation/scroll to "faster than light" and
...enable Entropy Fixer with value 256
– to prettify the build use
Xposed Framework > Starter Pack
Build will work on other rk32boards:
  (just change the kernel and resource in folder rockdev/Images)
Pipo P1: kernel #462, kernel #489kernel #537 (set dpi=320 in build.prop)
Pipo P8: kernel #153kernel #160kernel #167kernel #177 (set dpi=320 in build.prop)
Pipo P9: kernel #009, kernel #130, kernel #138, kernel #192
ifive mini 4: kernel #141kernel #14 (set dpi=320 in build.prop)
TWRP recovery see post #17
– Oma -
084-3.jpgImage Enlargerv1.1_03.pngImage Enlargerv1.1_01.jpgImage Enlargerv1.1_02.jpgImage Enlargerv1.1_05.pngImage Enlargerv1.1_06.pngImage Enlargerv1.1_04.pngImage Enlarger
oryzae, Flow63, admin
soukouzen
2014/08/10 - 10:23
Thanks Oma,I'm to domestic users to upload firmware.
Recently PIPO  out of a tablet called P9.
http://www.pipo.cn/index.php?m=Product&a=show1&id=342&cid=198&type=2
I also have it in the latest firmware.http://pan.baidu.com/s/1hqBrk24
The following users say thank you to soukouzen for this useful post:
2014/08/10 - 12:53
Thank you for sharing!
To make the firmware more usable for Pipo's overseas customer I removed all chinese stuff, correct gapps provider and Play-Store compatibility. Also the launcher and it's widgets is not longer included. Let me know if I killed too much. PinyinIME.apk is still in the system, only renamed to PinyinIME.apk_old.
The P9 firmware is Android 4.4.2 and comes with kernel #009. One can use my generic P4 build with that kernel, Just change it in folder rockdev/Images. I did a note here: http://crewrktablets.arctablet.com/?p=3882
soukouzen
2014/08/10 - 14:10
Oma,
       Thank you.You remove these applications is no problem, because we root also will remove a lot of Chinese applications. I do not know the firmware provided by a bug in your use, and I can tell PIPO engineer. If you can use China's QQ application. I can provide his ID, you can direct feedback bug.
soukouzen
2014/08/13 - 07:11
Hi,Oma,
Today I bring you the latest firmware gave the P4.
http://pan.baidu.com/s/1kT0vNQR
2014/08/13 - 08:28
The build is still from 08.08.2014. Kernel ins new: kernel #568 preempt 12.08.2014.
One can change the kernel in the running build. Use the RKAndroidTool, just tick parameter and kernel.
For me the build is stable. I noticed no major bug. Boot animation shows still 4.4.2 ;-)
Did Pipo publish change log's? Would be much easier ...
Still a creapy thing is the rknand driver/layer. Can somebody run this benchmark and post a screenshot of the results? Thanks in anticipation!
soukouzen
2014/08/13 - 08:57
This part of the official firmware provided, so I did not get the update log, sorry.
This update behind the plate 100 times in the rest of the keys will be several times cabinet heating problem, but fixes some BUG.
oryzae
2014/08/13 - 16:11
I really appreciate your intelligence.
RK3288 users are not much, so It is hard to get information of PIPO P4
It is experiencing battery drain problem and power of during sleep mode
arctabletje123
2014/08/14 - 10:24
Hello Oma,
with the new version (4.4.4) my tablet battery is going down so fast...
my battery went down from 99% to 6% in 19 hours....
19 hours 9minutes on battery
mobile standby: 58%
screen:24%
tablet idle: 8%
i did not have this problem with the old version. ( i think, but im not 100% sure)
2014/08/14 - 20:47
Try the kernel from post #6.
arctabletje123
2014/08/16 - 11:43
that kernel is the same Rileyrom using with his rom 1.3 ..
i also have problems my battery is going down ultra fast
2014/08/16 - 11:55
For battery drain set "Keep Wi-Fi on during sleep" to Never (settings/wifi/advanced).
Deep sleep issues are always kernel related.
arctabletje123
2014/08/16 - 13:07
i never had my wifi enabled...
2014/08/18 - 16:10
Have you tested the kernel from post #6?
2014/08/18 - 21:49
Update post #1 with build v1.2.
v1.2_01-1.pngImage Enlarger
70 Guest(s)
Devices in use: Desktop (49), Phone (20), Tablet (1)
Kaka88
Donalbert
halum
BlackCero044
BlackCero04
taylordahmer
